Well, after finally getting all the parts together, I have started putting the engine back together again...
Must say the biggest PITA was finding a front cover with the correct pump size, and water inlet position...ended up buying a new one.
Quick rundown of the parts going in this time include:
-Low compression pistons, with valve notches, and ceramic coatings. (Balanced)
-Cunningham rods were checked over. (Still Perfect, and balanced.)
-Crank was just polished again. (Balanced.)
-Performance cam from Trusted Performance, built by Colt Cams exclusively for Trusted Performance.
-Block was punched out 0.020"
-New injectors from Trusted Performance.
-New "Adrenaline" HPOP from Bob Riley.
-New '04 style wavey oil rails to replace the old '03 straight rails.
-New rocker boxes, valve covers, and branch tubes from '04
-Heads have Beehive Springs, hardened seats, brass lliners in guides, and back cut all valves along with the multi-angle valve job.
-New H-11 headstuds.
-New Billet Low Pressure Oil gear set from Elite Diesel Engineering.
-New EGR delete kit for the bottom of the manifold. All Stainless.
-New EGR valve delete plug. (Thanks Tyler!)
-Ceramic coated exhaust manifolds, up-pipe, and "Y" pipe.
-CFM+ Intake elbow for the water injection.
-Snow Performance Stage 3 MPG Max water injection with 7 gallon res.
....and a sweet set of 18" X 10" Mazzi Hulks with 325/60 R18 Toyo A/T's.
...anyone wanna guess what I'm doing this long weekend?
