Yep, looks almost exactly the same as the poly Bronco tank I have under my truck. :ford: Just remember that the filler neck is bigger than your factory rubber hose. And Bronco Graveyard has them for alot less.
On my first Bronco tank(a steel tank), I welded on a steel nipple that was the right size and proper angle. For the poly tank I ordered the Bronco rubber hose and made it work, though I'm not very happy with it.
one problem I found with this tank is the height of the exhaust outlet. I have the poly 33 gallon tank in my Bronco, and with my 4" exhaust I had to lower the rear hanger significantly. Theres a good 4-6" between the bottom of the body and the top of the pipe
