Engine Restore? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 6.9 - 7.3L IDI Diesels 83-93 Model Years
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 11-20-2009, 04:24 AM
Nitro Blazer's Avatar
Nitro Blazer
Offline
Member's Gallery
Engine Restore?
Anyone put this in their IDI? It's got a warning on it about Powerstrokes. I looked around and found that it clogs up the injectors and high pressure pump and all kinds of bad stuff on those.
I can't see why it would mess up one of these old mechanical engines but I'd like to get some feedback before i do it.
I've used it in almost all my old gasoline trucks and it really made a difference in them, especially my '94 Bronco, that thing came alive after an oil change with Syntec and Engine Restore.
Reply With Quote Quick reply to this message Go to the top
Old 11-20-2009, 05:45 AM
jroller's Avatar
jroller
Offline
Member's Gallery
Re: Engine Restore?
Its snake oil dont believe me call you favorite oil manufacture, find out what they think. Some of these guys have even had lawsuits brought against them for there claims. Car and Driver replicated the Slick50 advertisement where they treated one engine with the oil additive and one without, drained both oils and the one that was treated didnt last more than 30 seconds, which is the exact amount of time the untreated engine ran.
This Myth was busted awhile ago, so save your money and just put good old oil in your engine, not one car manufacture in the world has ever recommended putting oil additives in there engines. They should know.
  #3
Old 11-20-2009, 01:24 PM
jdc753's Avatar
jdc753
Offline
6Leaker
Member's Gallery
Send a message via AIM to jdc753
Re: Engine Restore?
I used it a few times on a small 4-cylinder plymouth to get rid of what seemed like a lifter tick. It definetly worked for me. Was noticable withought it and smoothed out with it. I think I would use marvel mystery oil instead for the same results.
The idi shouldn't have the problem the powerstrokes would have since the oil in an idi 4,000psi or anything.
__________________
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
  #4
Old 11-24-2009, 12:47 AM
OldSchool101
Offline
Member's Gallery
Re: Engine Restore?
If you are going to use anything as a oil additive, use Lucas Oil Stabilizer, I've found that this works best in a diesel. It will also help keep the oil particles together if the oil gets somewhat burnt. Have never seen anything bad come from this product. Its only about $10 a quart at most auto parts stores. It will help ticks, low oil pressure, and also lubricate the top end.
  #5
Old 11-24-2009, 01:08 AM
OVERSTROKED's Avatar
OVERSTROKED
Offline
Team Truckless Beer Man!
Member's Gallery
Re: Engine Restore?
I have used it in a few old gas trucks but would make it my last resort. It did cure the lifter ticks i was getting out of them and slowed a few of the oil leaks down too but like I said last resort for sure
__________________
NEW SUPER STREET TRUCK IN PROGRESS!!
Special thanks to Brian at BTS and Jonathan & Dave at SWAMPS for all there help for the 06,07, and 08 pulling seaon's.
4th in points for 08 in the Central Ohio Truck Pull Circuit Pro Street 3.0 class
  #6
Old 11-24-2009, 02:27 AM
tughill283's Avatar
tughill283
Offline
oil burner
Member's Gallery
Re: Engine Restore?
i dont know bout the lucas stuff but ive used the stp oil treatment in a gas motor.its like pouring molasses into your engine to take up the clearances between worn out parts.
__________________
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
  #7
Old 11-27-2009, 02:31 PM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Re: Engine Restore?
I used the ENGINE RESTORER in my 96 ford probe. It was using a quart to a quart and a half between oil changes. No it doesn't use any
__________________
  #8
Old 11-27-2009, 03:39 PM
Aljay's Avatar
Aljay
Offline
Don't EFN worry about it
Member's Gallery
Re: Engine Restore?
Just a Band Aid. I don't beleive in mechanic in a can fixes.
__________________
Overfueled for your pleasure !
  #9
Old 11-27-2009, 04:31 PM
nasty96's Avatar
nasty96
Offline
That thing got a Cummins?
Member's Gallery
Re: Engine Restore?
I have seen what can happen with engine treatment. It can coat everything and plug up stuff it shouldn't. If you have alot of oil use/ticks, I'd try a little heavier oil or live with it untill you can rebuild/replace the engine. Otherwise leave it alone, you may end up doing more harm than good.
__________________
Ford makes it, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
  #10
Old 01-01-2010, 08:28 PM
Wollffy's Avatar
Wollffy
Offline
Member's Gallery
Re: Engine Restore?
I have a rebuild that was just done. I have an oil leak by the oil cooler on the drivers side. What could be missing? I built crank pressure getting ready for virgin start, and found this...
Human Verification
(View-All Members who have read this thread : 15
95 5speed, Clint39, dieselman, Drzronnie, Dustin F2504x4, Etcetera, lincolnlocker, majwild1, monster-energy-825, Nitro Blazer, obspsd, rayrayray01, SNR, truckpullin_75, txgp17
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
