Will it work, or will it look like hammered dog chit? I envision the trailer hitch bracket hanging out in broad daylight.:doh: If you have this set up can I see a pic? TIA
or call up Grant Kustoms and have them make up the entire thing in steel, corner fillers and all so it blends in. get yourself a tailgate skin while you're at it.
I had a urethane roll pan on the red truck with a class 5 hitch. The roll pan did hit the top of the hitch if I recall correctly and probably should have been trimmed a little bit to fit better. I cut holes in the roll pan for sled stops to come out off the frame rails - it was a snug fit since it was urethane and it looked pretty good.
Powersmoker has Mikeys old roll pan with licence plate removed he can then slide his pulling hitch in. Maybe he can get some pictures in here.
