So I got this lift from a buddy minus shocks, and u-bolts. Wondering what everyone out there is running for a highway truck for the nicest ride? And I got blocks for the back do you guys suggest getting new leaf's? And just wondering if you need a drop carrier bearing for a 4" kit or not I did not see one with what he gave me.. Thanks guys.
my kit came with a 1in block and an add a leaf.I only used the add a leaf since my stock block is 3.5 inches.I have the procomp 9000's that came with the kit and they ride pretty decent but if I had the money,I would get bilsteins.They can be had on ebay new for pretty cheap.I had to drop my carrier bearing with some homemade spacers.You can get the though from any suspension place for pretty cheap.The back of my truck sits 1 inch higher then the front.
Best ride is as follows:
hanger lifts up to 4.5"
X codes added to hanger kits up to 6"
Icon lift springs used with hangers after 6"..ie 4.5" hanger with Icon 4" springs will ride better than a 8" spring.
ETC...
Lift kits and Bilsteins..I can get you whats needed. PM me if I can help.
Just make both the front and rear hanger and your set.
