Sumps are ready to roll. Here are a couple of new color combos. Pricing will be $249 for plain, and $279 for anodized. Have 4 sumps with 1/2 npt ports ready to roll, and from here out they will come with 5/8 oring. Any feedback is appreciated.
Are these designed to fit between the tank and skid plate? I want one to put in the bottom of my tank. it just needs to fit between the tank and skid plate.
That would have to be a very lo-pro sump--IIRC when I had my skid plate off there wasn't more than 1 1/2" or so of clearance between the plate and the bottom of the tank.
They will be available in just about whatever color you want. Orange is definately doable!
These sumps dont fit between teh skid plate and the tank, and i honestly dont know if itd even be possible and still maintain the function of the sump. we have always cut portion of the skid plate right below the sump and spaced it down with 2 inch strap, or some guys just run without the skid plate.
We're HOPING we can do a full system with the sump included for somewhere in the 900 ballpark. The bracket is going to have to be remade for the short bed trucks, or a different made and we can use the one we have now for the long beds. This would be sump, fuel lab pump, baldwin 2 micron filter, water sep, bases, mounting bracket, and -10 line to the pump from tank, and -8 or -6 line to the motor, depending on application. Obviously there are still some details to iron out, but thats kind of a ball park for the entire setup.
Sweet mine runs good now Tony hooked it up ! Tranny hates me in the tune he wrote for another OBS truck that runs 12's !! Oh well sorry to muck your thread up. Did you guys get any shirts yet I need an x tra large I will be in S.A. tomm.
you could always tig weld a sump on to a metal tank, wouldnt look half bad, and once you cut the hole there is no going back anyway. just make sure its sealed.
I ran a steel one for a few years, then when I did my fuel system this year I noticed it was delaminating. :doh: Now I have a plastic one from Bronco Graveyard. :ford: It's flat on the bottom in the center last I recall.
3M weatherstrip adhesive is awsome, I use it a lot.
