Ok Im a bit stumped for once. Running into an issue driving up the highway truck doesnt want to stay steady on the boost it bounces from 20 down to 15 or 10 then back up and then back down. Sounds like a hissing noise but I dont see any exhaust leaks, also weird sound coming from my stack almost like making that noise when the exhaust is under water or when a diesel is reving it at high RPMS.
Could be the solenoid. Had that happen on mine, changed out the solenoid and it was fine. It actually started doing it again recently though. Can the solenoid be cleaned or anything?
Ya traded turbo's you guys know me i dont stay with things long I try new things new set-ups, custom set ups etc. Thanks Matt I will send you some info again in a little.
HAHAHAHAHA kinda funny Hearing Danny talk about 6.0's oke:oke:LOLLOL
Feed line ??? Its the orginial one before I swapped to a Non VGT it flows oil just fine, found that out the hard way when i didnt install the gasket lol.
URGH if its not one thing its another, just found out my regulator is leaking fuel somewhere on the fitting BLAH havnet i spent all day screwing with the stupid thing.
107.4K members
