I'm just curious but... Why do you want to know MPH in the 1/4?
As a vehicle gets lighter it will/should get faster and quicker but MPH is a vague indicator of power as it relates to quickness. If a vehicle is climbing past the lights it due to bad gearing. A mentor once told me to aim for peak rpm at about 1200ft that would give the best shot off the line and leave enough to cross over rpm. Case in point a NHRA pro stock car will make peak HP at around 9300 shift at around 9500 and go through the timer at 10,000+.
As I said I'm not dissing but it just seems trivial.
If your using this post to mess w/someone just ignore me.
Rudys truck has more in it. They just havent caged it yet. Got to see it first hand in Gainsville last month. Why he was lining up with Gabbys standard cab cummins everytime nobody knows. But its pretty impressive with such little work. Fuel system is def. needed.
