I am swaping the rear end to another rear end. My problem is that the rear axle I have recieved has two passenger side brake mounts. Which means if I mounted my driver side brake caliper it would be in front of the rear axle.
I just need to know how to get the brake mount off.
That was exactly the reason, they use the same caliper. Problem was that the drivers side was prone to getting damaged because it was exposed in front of the axle. They added a pretty heavy duty shield to help eliminate that issue. Then on the later models, they moved it around behind the axle where it SHOULD be.
Good to know. I will rebuild my old axle later on. Thanks for the info y'all.
Also just checked Guzzle's web page.:ford:
