PCM Code by way of VIN?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 1999-2010 Super Duty General Aftermarket
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto Escrow
Thread Tools Display Modes
  #1
Old 08-06-2009, 06:59 PM
JCart
Offline
Member's Gallery
Hey G & G's,
Have a buddy of mine that I want to get a chip for, thing is can not access his PCM code right now, would it be linked from the VIN? I.e., if I phoned the dealership with VIN would they be able to get me the PCM code? Do I have to pull the PCM out to get the code off it? Can I get it with a Superchips code reader? It's an F350 03 SD 7.3 Litre ZF-6 CC dually...with 4:10's and he put on a ball buster turbo, MBRP single and AFE intake. Uses it for work aluminum flat deck, tows to max GVW and also pulls various light to no loads with it. Thinking TW files looking for max tow, light tow, mileage and race files any suggestions would be great.....
Thanks,
jrc
__________________
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, SRK, SD springs front/rear, 145 litre rear tank (now ZF-5 ).
White / Silver 96 F250 4x2, SCSB E4OD, 4:10 stock for now mods to install: D60, engine stuff.
Truck pix write ups
Reply With Quote Quick reply to this message Go to the top
Old 08-07-2009, 03:55 AM
southmike's Avatar
southmike
Offline
Village Idiot
Member's Gallery
Re: PCM Code by way of VIN??
some pcms can be read with a mirror etc..
some have a tag . there were more useful instructions on the use of the mirror etc possibly on dp~tuner's site or elsewher i forget where though.
but my advice is
i would not inform the dealer of anything pertaining to a pcm.
i would possibly ask to go get a "paper" he left in the truck
and have a look then.
__________________
  #3
Old 08-09-2009, 07:25 AM
PowerHungry's Avatar
PowerHungry
Offline
Forged rods R 4 SISSIES!
Member's Gallery
Here's a link to some quick instructions on where to locate the PCM code.
How to find your PCM "Box" Code
A Superchips programmer might be able to provide the information under a diagnostics or utility menu, although I couldn't say for sure.
Tony will be able to get you fixed up with a really nice set of files. You won't be disappointed.
Good luck.
__________________
Bill Cohron - (678) 890-1110
www.gopowerhungry.com - The Original in Custom Ford PSD & Gas Tuning since 1997
FOREVER
2001 7.3L - Stage 1's and a Tymar - 399 HP
2004 6.0L - 440 HP #2 Only/482 HP on Boost Juice - 12.961 @ 102.6 MPH
  #4
Old 08-09-2009, 10:22 AM
dixieland-diesels's Avatar
dixieland-diesels
Offline
owner/president
Member's Gallery
Send a message via MSN to dixieland-diesels
Yes you can get the PCM code through your vin #.
__________________
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
  #5
Old 08-10-2009, 04:18 PM
SeeYa's Avatar
SeeYa
Offline
Sponsor
Member's Gallery
Originally Posted by JCart View Post
Hey G & G's,
Thanks,
jrc
To install the chip you'll need to pull the PCM anyway, but you can pull the black plastic housing off the PCM from inside underneath the dash. to find the PCM code. If it has never been chipped there will be a cover over the J3 port with a sticker. The 3 letters and 1 number on the PCM is the calibration code.
Easiest way to get it is this- Its either going to be a federal PCM code of AEB#, or a California coded PCM of ZRE#. For Cali. you will have 1 glow plug relay and a silver controller box with heat fins for the glow plugs. Fed's have 2 brown relays for the Glow plugs.
Check it out and see which one he has. Tell your tuner; they'll know what code to use on the chip.
Diane
__________________
Diane @ DP-Tuner
828-221-0076 x 802
  #6
Old 08-10-2009, 06:28 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Good info right there.
__________________
  #7
Old 01-24-2012, 09:54 PM
pitbull62's Avatar
pitbull62
Offline
Member's Gallery
yea i know old thread...so just call in vin to dealer and get info?
__________________
2002 F-250 XLT 4X4 White BULLETPROOF 7.3 PSD CC Longbed, SRW, Auto, Edge Evolution, 4.56 Gears, 8" Edge Suspension, 35" X-Terrain radials, 16 X 10 Eagle 102's, Rancho RS9000'S, Tymar intake, DPPI 4" DP 4" exhaust, Autometer Ultralite gauges, Stull billet grill, Cyberwhite backup lites, Tekonsha brake controller, Truespeed SUPERDUTY PICS
  #8
Old 01-25-2012, 06:54 AM
tbolt's Avatar
tbolt
Offline
Member's Gallery
not always. My e99 has an 01 pcm in it. Pull the cover off and look.
__________________
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
Human Verification
(View-All Members who have read this thread : 123
03threefiftyz, 04fatboy, 06 f250 man, 1BadF350, 7.3 Ford, 97250HD, 97powerstrokeboy, a5t1, Arisley, BeringSeaFisher, bigblocktisdale, BigBlue7point3, BigDaddyJob, BigDirty '04, biggreen96, bigjake0524, BigRed97, BKex, blk7.3ks, Buffalo444, Bushwakd, c.salt, Calico5, CGMKCM, chadder1313, Chatham036, chris 0., CLIFORD3, cloudd21, Cmonster, cody342b, corybens11, crewcab7.3, crowz, CSIPSD, dan-devries, dark20011, Dave, dave186, dblamp, dieselford000, DIRTBIKEZ, dixieland-diesels, drunk on diesel, Fire370, Firehunter, Gibrid4x4, grantw1221, jarz, Jbgabriel, JCart, Jeremiah25, Jerodl, jgos929, jim17, joedown, Johnboy3, jonstangnelson, ju015dd, Justin@DP-Tuner, jvencius, Kaborkian, kbnord, kilapapipa, kminor3434, Ks94.5powerstroke, machete31, mattgw86, merlinnilrem, mnstroker, mrgto, mspainting, never enuff, NevrKnow, NorCal997.3, ntgd1, Ohnny101, old man dave, patrickke, Petro, PHPDiesel, Pipewhiner, pitbull62, powersmokin88, powerstroke095, powertrip, renyren, Rilli_Chefen, Rockcrusher, Rockyardjo, Rodknocker, Rowe, rpm-inc, Sapps, scheidt27, schmity, SeeYa, Shep, smokinford07, sniper_101, southmike, SPless, SuperStroker91, swaan, tbolt, TheDirt, theron1128, tim02f250, Tommy69Z28, turbodeezul7.3, umpalumpa1985, userma3648, vapstroke, Vdryv, whitty, wsigo, ZaC851, zack7.3, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
