OUO traction blocks i'm guessing your talking about...do a search oke: few people running them and they are affordable if you can afford them, for what they are they are resonably priced though
just bought a radius am bushing off a 90 f-150, if i did it again i would use one off a 70's f-150, then just used a plate with just big enough of a hole, and a 7/8s bolt welded inside the tubes.
Tom I used a set of ford front radius bushings like what goes on the front of our OBS trucks 2wd . I used the bushings and welded a bolt that fit the bushings in some heavy wall square tubing.
