460 ZF same as 7.3 ZF? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 07-29-2009, 12:10 AM
CNDiesel's Avatar
CNDiesel
Offline
PSD
Member's Gallery
I found a rebuilt zf5 trans for sale but it is oringally out of a gas 95 460 trans...
Would this work to replace my zf5 in my 7.3?
Or if I could swap the internals from one to the other.
__________________
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
Reply With Quote Quick reply to this message Go to the top
Old 07-29-2009, 12:27 AM
Super_Hauler's Avatar
Super_Hauler
Offline
Super Hauler!
Member's Gallery
Re: 460 ZF same as 7.3 ZF?
IIRC case is the same but internals are different, including the light duty converter.
__________________
MINE:08 F-250 CCSB king ranch erics tunes livewire
99: sclb 6 speed, 4" lift,4" exhaust, EB
99 F-450: ccfb Boss v plow. 6 speed 5" ex,EB
HERS:2001 F-350 ccsb notta stock!
  #3
Old 07-29-2009, 12:30 AM
dstruble's Avatar
dstruble
Offline
Just A Squirrel
Member's Gallery
From my research for my '56 ford 460 swap is the case and the gear ratios are different between the 7.3 and the 460 zf's. FWIW
__________________
Darrin Struble
2003 F-350XLT Sport SC/SB
7.3L Live tuned by Jody ,ITP reg return/intank prepump mods, MBRP S.S. 4" ,afe stage1,foil delete,WW, Dieselsite coolant/trans filters,turbomaster wastegate controller,FTVB,Bandwagon Badges
1956 f100 Heidts Suspension all around
  #4
Old 07-29-2009, 02:51 AM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
the bell housing bolt pattern is different form a BBF to a diesel
__________________
  #5
Old 07-29-2009, 03:07 PM
moore20017.3's Avatar
moore20017.3
Offline
Member's Gallery
There is no converter on a ZF-5.
I do not know the answer to this, don't see there being a difference in gearing.
The 460 and 7.3IDI and PSD all share the same bellhousing to the best of my knowlegde.
I would think the only major diff would be the clutch/flywheel. Someone will chime in with good info.
  #6
Old 07-30-2009, 12:43 AM
12v Ford's Avatar
12v Ford
Offline
Member's Gallery
I know that when you do a cummins conversion, they sell different adapter plates for the gas zf5 and the diesel zf5, so they have to be different.
The s5-42 tranny has different ratios than ths s5-47. The s5-47 was mostly used in the DI powerstroke and required a synthetic fluid. It was also rated for a little more torque
s5-42 s5-47
Rev 5.24 3.79
1st 5.72 4.14
2nd 2.94 2.37
3rd 1.61 1.42
4th 1.00 1.00
5th .76 .76
Clutch is different too, of course.
__________________
Mine- 1995 Ford F-350 XLT CC 2wd DRW LB, ZF-6sp, '96 215 hp Cummins, SBDD, #10, SDX 5x14s, HE351cw/S475/1.10 twins, and other good stuff
My Newest-1995 Ford F-350 XLT CC 4x4 SRW LB, 460 gas, auto, Soon to be 12v Cummins, 4r100 and 700hp+
Wife- 2008 Ford F-350 Lariat CC SB 4x4 SRW, 20" factory wheels, navigation, sirius, all stock for now
  #7
Old 07-30-2009, 02:38 PM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Zf gearing changes between a 42-47 and a gasser(close ratio) and a diesel (wide ratio)ZF Manual / Standard Transmission Identification Parts and Diagrams
And yes the BBF is a differnt bell than a Diesel. You can use em but you have to heavily modify
  #8
Old 07-31-2009, 01:05 AM
CNDiesel's Avatar
CNDiesel
Offline
PSD
Member's Gallery
What are ways that I can tell a BBF zf from a PSD ZF?
Doesnt the gas zf use a internal slave cylender (not to sure on the big block ones)
Heres the one for sale.
And here is mine I pulled yesterday.
Take in mind the guy selling this has numberous ZF5s and isnt sure if this was a gas or a diesel trans.
  #9
Old 07-31-2009, 01:53 AM
kainers's Avatar
kainers
Offline
Starting Over
Member's Gallery
it looks like the alignment dowl is different on what is the right side as you look at the pics.Hell left side too somewhat
What would it take to put a ZF6 in there?
  #10
Old 07-31-2009, 02:20 AM
smorris's Avatar
smorris
Offline
you want some of this?
Member's Gallery
Got one of each here at the shop. Bellhousings are different for sure.
Not sure on gear ratios, but I havew swapped out the zf in a 95 powerstroke OBS rollback, and one from a 96 reg cab f-250 powerstroke.
The f-250 had the lower first gear. Both were factory trannies.
So, it may not be a gas vs diesel thing, might be just different build dates, or possibly just optional gearing, or maybe even different for trucks with different rear gears as the 350 rollback has 5.13 I think, and the 250 had 4.10
It is very easy to swap the case as long as you turn the right side up before slidng it apart! hahah
DONT ASK!
__________________
2000 f-350 cc lb dually 4x4, BTS transmission
7.85@ 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
http://community.webshots.com/user/smorris1972
Incompatible Browser | Facebook
Registration Verification
Enter the first character in the word "Powerstroke".
Insurance
Please select your insurance company (Optional)
Human Verification
(View-All Members who have read this thread : 160
02BigD, 03_PSD, 12v Ford, 1997F350powerstroke, 307diesel, 7.3powerstroke03, 86turbodsl, 887.3DirtyD, 93idi2007, 94psd5speed, 957.3powerstroke, 9576brxlt, 97Heavy Duty, Adam0331, amccarty, amcguru, AZFairlane, baderic03, Bamboo, Bartlett99, Believer45, BigJake, bigwhite95, bjc, blk97power_stroker, BME460, bodaciouscj7, BoomerL37, bpa658, Bradbilt, brads96 stroker, broncoguy, Bugman, catch22, CNDiesel, co04cobra, Coal_Roller_13, cp3504x4, ctoney063, cumminskiller69, czangli7, d21067, DALT 6.9, damons250, Delox, Derailed, dieselbronco93, Dieselfever, DieselRangerKid, DieselSmokinYall, dieselthrash, dstruble, EverettWV, f-rag, farm boy, FordBoy86, fordguy95, fullsize, ghostang93, Glen87, golfer, goodintentions, Harl, hcwt, hookin78, IDPisan, INTPSTROKE96, iowawiley, ironworker40, Jnewsome368, Jngreen, John v, John_DeereGreen, jonboy84, Jordy53, josh1.123, joshua.a.rackley, ju015dd, junk, K5383, kainers, kbrown04, konzkustomz, kpasichnyk, Ks94.5powerstroke, logcruiser, lovemytruck37, luv_my_stang67, m j, MadMax'97PSD, madpogue, MagKarl, matthewd11, Matt_P, Mendomotox, Mike97f350, MilehighEX, mj1193, moesmokebbq, Monstar, moore20017.3, mustangracer42, nashvillebill, nasty96, NDPSD, noshoes, obs stroker, Obspsd7.3, old man dave, ole_blu, outlaw 4017, ParkerFly, paul24, PJB, powerstrokefarmboy, powerstrokenstang, psdmike, PSDTECH97, pstroke96, rausch610, Reubine, rickh, rideracelivemx7, rridgway, RSP, Schneider 86, Scottapher, sevenpointthree, sg465, silverslug, smorris, SNR, SS496, StandAlone, superdutyfarmer, Super_Hauler, The Fireman, The Fordman, timmay316, toads250, toolmangary, TRUBBS, tughill283, txoutlaw, TXstroker01, Tylerjm7.3, u2slow, USMCTJ13, wds1279, willholl79, WilliamBoss, wjamesm, WolfTraxx, yzdude250f, Zaenglein, zpilgeram
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
