hey ive tried a few different style lifts kits but none seem to work looking for ideas i got an 06 f350 and i got a fisher plow. every lift ive put in it seems to fail after plowing.:ford:
will definitely get more views in the appropriate section
I would recommend sending a PM to Dan (DCspecial) He is one of the resident suspension experts and a rep for Truck Toyz Performance. I don't know all the details but I think he might run a leveling kit in his plow truck, I know he mentions it has something like 7000lb coils or something a little heavier.
I would think for plowing something along the lines of a spacer style leveling kit would be best and stick with the heaviest factory coils you can get. Unless maybe its other components that are failing.
As Buff mentioned Firestone does make airbags for the front that you could possible add to take much of the weight off the coils themselves.
It has more to do with the weight rating than the hight. A good idea if you are just trying to level the truck would be stock coils from a plow prep truck with steel spacers and a set of air bags just incase you need a little extra. Im shure DC will see this at some time and he has a nice setup on his truck.
have you checked out bds yet? I know they will replace any broken or worn out/sagging parts free of charge. May be worth a try or can do the above to prevent any sagging from happening.
i wanted to run 32 inch tires on the truck and i was considering like upgrading to 550 springs see if that would work but ill look into what you all have offered as well
I am pretty sure that the factory 18" continentals are 32" high and the factory 20" tires are 34" inches high, so you should have no problem running those tires without a lift at all.
Air Aid also makes an airbag kit to fit inside the front coil springs, and I know I've seen them used on a F-550, so they could be used with some 7000lb springs.
