| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Changing Glow Plugs?
I was wondering how hard it is to change glow plugs on a 6.0? I just bought 8 new International ones and want to get them installed when I have the time. Anyone know? Thanks.
__________________
Andy ~2003 Ford F250 Auto Lariat 6.0~ |
| Sponsored Links | |
Advertisement |
#2
Re: Changing Glow Plugs?
Take off your Valve Covers, when you install get new valve gaskets as well.
__________________
Real Trucks Burn Diesel |
#3
I heard that you can do it by pulling off the rail thing that goes to each glow plug and fish them out with the magnet. Is it easier to just take off the valve cover?
#4
Yea, because you gotta replace the valve gaskets.
#5
No offense king diesel but 6.0 valve cover gaskets are reusable and you dont need to remove them on a 6.0. Just remove the glow plug harness (external below the valve covers) and use a socket and magnet to get the plugs out. Its really quite easy but alot of the time you wreck the glow plug harness as it has become brittle from age and heat.
Might no be a bad idea to have new ones on hand if you can return them incase you wreck them.
__________________
2000 f-250, dp f-5, ddp 120hp single shots, mbrp turbo back, itp boost fooler, itp pre-pump kit, banks billet torque converter, coolingmist cmgs |
#6
Ummm you also reuse the ones on a 7.3 also
__________________
1999.5 F-250 7.3l 4x4 6 spd Ported Heads, Head studs, valve springs, DI Push Rods, DI RR, 38R, Walbro fuel pump, 238cc Injectors from Nate @ Unlimited Diesel and Tuned by Matt @ Gearhead Automotive Dynoed 520hp and 926tq on 5/23/09 Dynoed 516 hp and 1121 tq on 4/24/10 |
#8
A little late to the game here, but wanting some more information, if someone would be so kind?
I own a 2005 Ford Excursion with the 6.0L Powerstroke and I'm reading conflicting things when searching both here and on the internet. Am I correct in understanding that very early 6.0L Powerstrokes used a bussbar that needed to be removed, but at the end of 2003, they started using a new harness? I am rather new to performing this sort of work, but I am patient and it is not my daily driver, so I can take my time. Does anyone know where I could find a photograph of either side of the engine and indicate what I am looking for? I've found photographs of the bussbar, but again suspect that was on the very first 6.0L Powerstrokes. (I could very easily be mistaken!) Also, the photographs were of a yanked engine with almost no accessories installed, so it did not give me a good idea of what and where I should be looking for. Any advice, I'd appreciate it! I'm needing to plug it in at anything colder than 10C (50F) otherwise it starts so rough it feels like the entire vehicle will rattle itself apart. Plugging it in, it's starting smooth as glass down to -5C (23F) so far. But I dread it when the weather gets colder... |
#9
Diesel Technician Society
Try this it has all the model years, It does look like the first 6.0s have a bus bar.
__________________
http://www.dieselpowerproducts.com/ |
#10
Tips:
In 2004, the combustion chamber on the piston has been modified (updated bowl design). Due to the design change of the piston, the glow plug has been made shorter by 1.2 mm. If the longer glow plugs are installed into an engine with updated pistons, glow plug to piston contact will result, ending in potential catostrophic engine failure. Glow Plug Removal Tool - from Ford glow plug removal - TheDieselGarage.com If you want to change the glow plugs- there is a small trick to removing the glow plug harness. The harness is located right at the bottom of the aluminum portion of the cylinder head- use a peice of 16 gauge wire to pull out the connector. There is a ring at the bottom of each connector, wrap the wire around it then yank the wire with a pair of pliers. The glow plug is 10mm, just remove and reinstall. Video w/ a short excerpt on glow plugs at apprx. 6:00 minutes: Install an inductive amp meter on one of the main glow plug harnesses. You can get up to 200 A at first, but then should stabilize around 35-45 A. Check the other side. Both sides should read the same. If not, check the amps to each individual glow plug to determine which one (or ones) is bad. Each glow plug should draw 10-12 Amps. mms://multimedia.ford.com/seopts/Tech25_250k.wmv
__________________
Mark 06 F250 CC SB FX4 Lariat;ARPs OEM gaskets;Banks exhaust;DynaTrac Balljoints;RACCCV6000;Updated HPOP fitting;JimmiJammers;Ravelco;plugs&standpipes;Fumo to;Harpooned;Quadzilla XZT Fuel Press;Blue spring;DashDAQ;PHP_FICM; RiffRaff boots;DCPower250A w/ Inverter;Rancho7000's;BPD EGR cooler;BPD WaterPump;SCT Matts SRL+;ELC Ultra w/ filter;SynchroMax |
#12
I do plan on going to them for the glow plugs though, as the changes in the different model years make me nervous about accidentally purchasing the wrong ones. I get my parts there at cost due to a deal with the last truck I purchased there, so it works out to be about $15 CAD per glow plug. Not a stellar deal, but better than the $25 they normally charge. Thanks again for all the help and suggestions. :) |
#13
Try the International Dealer if You have one near.
They are usally close to half the price of Ford. |
#14
I replaced the spark plugs about one month ago and have a quick question: are they supposed to be covered in oil? Also, that wasn't the source of my no-cold-start. D'oh! I'm suspecting the FICM now and am going to be checking for 48V off of it this weekend. I'm actually hoping it is the FICM because it could get a lot more expensive if it is not. |
#15
So the question still stands: are the glow plugs supposed to be covered in oil when removed from the vehicle? |
#17
yes
#18
Hi guys,
Is there any trick to remove the passenger side glow plug buss bar on a 2003 6.0 f350? I´m having some trouble right now. here i leave you a picture. I already removed the right inner fender. thanks |
#19
I'm curious where this oil comes from on the glow plugs? This is normal?
#20
Telling someone they need to remove valve covers and replace gaskets when neither have a dang thing to do with replacing glow plugs on a 6.0 is assinying. You could cost him lots of money and time. YOUR COMMENT REALLY SUCKED!!! |
#21
Do you realize your commenting on a 3 year old post????????
#22
I had a mechanic butcher my wiring harness while replacing glow plugs. The ####### reinstalled the jacked up harness with wires exposed and Im concerned. Should I be worried about them coming loose or shorting out if the boots are not attached around the wires going to the glow plugs?
Thanks for any help... |
#24
It isn't too bad. I wouldn't want exposed wires. Can you not just tape the bad areas?
#25
No, Im new to this and have no idea what Im doing at this time. Thanks for the info...
#26
I dont think tape would hold long term and it would look like crap. Im the type that keeps the engine clean and undercarriage. I want everything to look professional. I also dont feel the connection is as stable if the boots are not snug in the plug cavity.
#27
I hear ya!!
#28
I picked harness for each side from Ford today. Felt like they gave me a fair price. 83.75 for the pair.
If you are self employed just add and deisel repair to to your company name and you are buying wholesale. That was easy. I dont think it will be that difficult once I remove the tires and possibly fender wells. What do you guys think??? |
#29
Removing the fender wells helps. Some people put the wires on them ahead of time so that they are easier to remove if you ever have to.
#30
what do you mean "put the wires on them ahead of time" ?
I appreciate your responses.... I think I know what your referring too. The 16 gauge wire to remove the plug harness? |
#31
Here is some advice on removing glow plug connectors:
There is a ring at the bottom of each connector. Wrap a piece of 16 gauge wire around the ring and then yank the wire with a pair of pliers. If you attach the 16 gauge wire ahead of time, it makes removal of the individual plugs easier next time - just a thought. |
| Thread Tools | |
| Display Modes | |
