no idea..just saw some white residue down in the wheel well..figured it was from the body shop..popped the hood..and that what i found..just a minute ago.
i talked to tadd..he thinks the oil cooler took a dump, because i overfilled it a couple weeks ago..its only oil on coolant...i hope thats it. if its oil cooloer ill go to dealership..if its headgasket..ill handle it . if its headgasket im done with this thing.
Where's the oil at? If its venting coolant from the degas bottle cap and you deleted the egr coolers then u have blown headgaskets it sounds like. But check your degas cap and make sure its holding psi, i have seen a few caps bad already on the 6.4.
Id say if it takes 600+ to pop the gaskets, its not that bad. a cummins nor dmax can do that. The dmax's rods might not even be happy about it.
I wonder what the flatness of the heads are like compared to that of the 6.0. You have studs correct?
The 6.4 has a much shorter bolt/stud, and a more solid head with less bs to be cinched down while clamping, but they still have mls gaskets which require a good surface on the heads. the 6.0s did NOT have this.
its got studs and the degas bottle has oil. if its blown, the spray is coming off, the studs are getting swapped for stock headbolts and thats it. ill keep it... guess it was too good to be true..
if its an oil cooler though i dont see tuner or spray having much to do with it, unless im missing somthing :dunno: If its the cooler just bypass the stocker, with an oil-to-air cooler instead
its all good, i have heard a few with cooler problems even stock. hard to say sucks though, im sure you'll keep us posted, external waste gate... you can send me yours...
