It looks like there may be a crack on the outside of the hub assembly, I am assuming that is what is causing the leak. I am assuming the hubs need to be replaced, they are not rebuildable? Sorry if I sound like tool but I have not even seen them, talking to him via cell phone
There is nothing in there to leak out? They are vacuum activated hubs. Other than maby a little grease there is nothing to come out. The big snap ring around the outside edge holds them in. Pull the snap ring and pull the hub locker out.
Try and get more info if you could?
Not all are vacuum actuated (mine aren't!). Judging by the description, it sounds like the outer housing is busted. The only thing in there to leak would be the little bit of grease keepin' it all slick.
