Is this just simple condensation from something, or do I seriously have a leak? The truck runs fine, or at least I think it does. This fluid is just a little concerning considering the volume. It doesn't smell, it doesn't appear to be any sort of oil, coolant, or anything like that. Just appears to be water. Any ideas would help.
That's what I was hoping, but it just seems like a lot more than I'm used to. With the problems I've had, I get a little nervous when there's fluid on the ground.
I had a coolant leak right there about 6-7 months ago. I put on an EGR Delete kit, and it went away. Last week I noticed an unusual amount of "something" in that same spot. After doing a few little self tests, I found out that it was indeed the AC. If you can, try running the truck without the AC on for a day or two and see if the spot comes back. Hope this helps.
My ac flows water like a faucet on these hot summer days. I mean it's almost a steady pour but have yet to have any probs and it's done that since I bought it. Got good air though..
i had a busted injector cup that ended up shoving fuel into the overflow tank and that would leak all over and around my right tire....
