I am replacing my rear axles seals and wheel bearings and I am stuck on the re-assembly. I had the inner bearing race pressed in at a machine shop, installed the bearing and installed the axle seal. I put the hub back on as well as the inner race and bearing. When I try to re-install the special axle nut it seems like there are not enough axles threads showing for the nut to engage. Am I missing a step or is there a trick to this?
that was my next thing. If the races arent in all the way, the hub will not fit properly...
107.4K members
