I have seen alot of front bumpers with the custom fogs are those aftermarket are custom fabs. If custom how bout some pics of the process.. If you dont mind seeing a couple more like it...4" or 6" round fogs??? I am asking both DC and Unbroken
Are you cutting the wholes and then welding an inner ring then alittle filler to smoother out?? I really like the look and live nowhere near you guys to have you build me one reasonably so just think'n of a good fall project. They look badass you should mass produce and start your line on that note......
Also DC I was checking out the ouo blocks and suck been think'n of add'n an extra 2" to my 8 so I can get an even ten. Will I probably end up replacing shocks over that 2"?? I will be gettin those blocks shortly.
Depends on what shocks you currently run, you may be able to simply rotate the lower shock mount on the axle to help make up for the height. What shock do you run?
Yea, I think it would look awesome in a nursery supply yard, with piles of gravel, mulch, and soil in the background. Then some shots from down low if it "stalking" through the nursery plants, DO IT BALDEY!!!!
That was just glare from the suun that day...the tails are much darker than they look in the pics.
And Im not tinting my headlights...I spent about 600 bucks on lighting not counting the heads themselves to be able to actually see at night.
Yeah, the tails are smoked pretty good.......just the sun was bright and went right through the "smoke" LOL
