I noticed some bubbles in the old overflow yesterday and instead of tossing in studs Im going to pull the heads and put some ported pieces on.
My question is this, I have noticed that many of you are not using these, the fire rings, is it not worth the money. I am not pulling the block so I don't think cometics would work without the required machining.
any input would be greatly appreciated.
I am going for big power int the long run and I don't like to do things twice.....
We've been running our fire ring kit and H11 studs in our race truck for 5 years now, over 110-psi boost without a single headgasket issue. With proper machining of the heads and proper torque sequence, it's a pretty solid and proven set-up.
Now according to a guy that runs around here with some and a 7.3,He supposedly blew his fire rings because he started beating on it a little before the motor got up to temp fully.Are they really that touchy?
I assume your talking about me. Even if your not let me weigh in on my experiences and help clear this up. My fire ring setup does not currently seal completely until the motor is up to temp. They are not blown, they just leak like every set of fire rings. NOW the ***/Hypermax fire ring kit is set up differently than what I am running. Thier kit blocks off certain water passageways where the leak is most likely to occur at. Since thier setup does this the combustion gasses don't get into the water jackets and the motor can get up to temp and fire rings seal up no problem. Thier setup should be fine for a DD. Since my grooves are already cut I have to stick with the ring setup that I have, but I intend to block off the water passageways in much the same way on my motor to help solve that issue.
Cometics and H-11s seem to be a good choice as well.....
