Has anybody swapped 08+ springs on to 99-07 trucks? I ran accross this on EBAY today, just wondered if anybody had done it.
http://cgi.ebay.com/ebaymotors/1999-2007-F-250-F-350-Superduty-Leaf-Spring-Conversion_W0QQcmdZViewItemQQ_trkparmsZ65Q3a1Q7c66Q3a2Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3911Q2ec0Q2em14QQhashZitem3ca2ec96cfQQitemZ260431451855QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessoriesQQsalenotsupported
Has new mounts that move your front leaf spring mounts forward.
If you just moved the front spring mounts forward, wouldnt the axle be too far forward if it was centered on the leaf spring? Since the rear spring mount stays in the same place.
My thinking is, If I could pick up a set of 08 leafs and the spring mounts I need, I could do that and run a 6" OUO Traction Block.
I talked to the guy that had the kit listed on EBAY. I asked him the same thing I asked in the post above. His response was:
No, just think if you welded 8 inches onto the front of your current leaf springs…..the rear shackle and axle center pin remain in exactly the same place, its just that the front eye is moved forward by 8 inches….this actually makes the leaf springs the same length in front and in back of the axle like it should be….the 99-07 design is really a terrible design because of the shorter front section really affects ride quality and limits maximum load….
Like I said, we have them on all of our company 1999-2001 F350 duallies, and it makes a huge difference, both in ride quality and weight carrying capacity, and there were absolutely no issues with regard to axle location, simply removing the existing front hangers and replacing them with ours 8 inches further toward the front is all that’s necessary….
