can you put a f350 or f250 leaf spring on an excursion..It sags real bad when towing and figured that would help alot...what would have to be done to the front to level it out
Yes, Superduty springs will work on the Excursion.
Excursion were spec'd with springs to give a soft and low ride to make taking the kids to soccer practice more comfortable.
If it was me, I'd at least replace the Ex springs with stock SD, but even better put 4" Icon front springs on and F250 springs with a block to level out rear. Air bags would be a good addition for towing.
What you want is V codes in front and B codes in the rear doing my B code mod. This will raise the front 2" and the rear 1" you can add a 2" hanger kit to get it level..depending on your rear block.
Adding correctly valved Bilsteins and adding a 30MM SD truck rear swaybar will finish it off.
You do not want Icon 4" fronts and a block in the rear!!!
I have helped dozens with fixing the handling problems of the Ex.
If you would like prices or additional info please email or PM me with your needs, info on your truck and zip.
I am a Dealer for: Garret turbos! Casserly Injectors! Icon Vehicle Dynamics, Rize, RCD, Full Traction, Pure Performance suspension, Bilstein,RS-SD kits for OBS trucks, BTS Trans, John Woods trans, STak transfer cases, Deaver spring, Tony Wildman chips,Stealth HPOP's, Tymar products and a Hella dealer among many others.
Custom SCT tunes by Cale at BTS!
If I can help you with your truck please let me know.
I also carry: Iron Bull bumpers,Proto Fab and custom bumpers and offroad specality products for Full size trucks,
Bronco's, Jeep or Toyota's!
Cary
107.4K members
