Pulling up to a stop sign headed home from work my truck shut off and died.Shell crank but no fire.You guys have any ideas? Dead HPOP or FICM.It ran fine til I went to stop.Its also been crankin longer to start sometimes lately.
you guys think maybe a cracked tube,bad o-ring, or maybe pump...Im tryin to figure out how much its gonna cost.I got a comp. on it today and Im pullin 200 psi out so its still got a little juice in it.
I agree with the others... An 05 with your symptoms, the HPOP system is likely the culprit.. Has it had the STC fitting replaced?? That was a common issue on 05's...
