ebpv removal to remove turbo? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 OBS Power Stroke - Aftermarket & Performance
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 05-16-2009, 10:34 PM
rideracelivemx7
Offline
Member's Gallery
any one have a guide of some sort or a picture to show me how to remove the ebpv unit in the back, i have all the bolts off and thats the last bolt and i just cant figure out how to the dang thing comes out!
Reply With Quote Quick reply to this message Go to the top
Old 05-16-2009, 10:56 PM
Harl's Avatar
Harl
Offline
Harl
Member's Gallery
Send a message via AIM to Harl
Re: ebpv removal to remove turbo?
When I took the turbo off my extra motor i just pulled the turbo and all...
__________________
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
http://www.youtube.com/truerednecks
  #3
Old 05-17-2009, 06:12 AM
old man dave
Offline
Terminator Nation
Member's Gallery
Do you mean the pedestal mounting bolts? These are probably the hardest to remove bolts in the truck.
Use a 1/4" drive 8mm flex socket, an extension (6"-10" as I recall), and ratchet. I use an adaptor to 3/8" drive ratchet for a little more leverage. The driver side bolt is the hardest, come over the top of the turbo and get the socket onto the mounting bolt. The bolts are tight, so use a high quality socket set. To get to the passenger side, drop the downpipe, remove the EB
PV housing with 8mm 12 point socket and extension (3/8" drive works here), and use a box wrench to get to the bolt. It takes a while so be patient.
To reinstall the driver's side bolt, use electrical tape to hold the bolt on the flex socket and get it started in the hole after starting the front mounting bolts. Start the passenger side rear bolt. Then torque in sequence.
If you mean the lower big turbo flange bolts, I cut a cheap combo wrench in half, put the box end on the bolt and tap it with a 4 or 8 ounce hammer. It comes loose. I didn't believe this would work until I saw my buddy remove the bolt in less than a couple of minutes without penetrating oil.
__________________
Just another 408hp '97 California Truck with a stock muffler
  #4
Old 05-17-2009, 10:11 PM
rideracelivemx7
Offline
Member's Gallery
i used the swivel on the easy to get ones, ish, but i used 2 4" 10mm craftman wrenchs and interlocked the open end with the boxed end on another wrench and pulled, it crakced the bottom uppipe flange bolts and the rear pedistal bolts loose, great and cheap technique, just have to get in the right position.
Registration Verification
Enter the first character in the word "Powerstroke".
Insurance
Please select your insurance company (Optional)
Human Verification
(View-All Members who have read this thread : 77
01strokin, 16yrenthusiest, 17degrees, 95powersmoker, 96 F-450, 97strokethis, 997.3PSD, Aaron Ford, ADubDiesel, BadDogPSD, Bamboo, Black Beauty 7.3, boondocker13, CanadianGTR, Centxdiesel, Coalroller, Copperhead, copperhead99, D.T.Starr, davewild, DcMoore999, Dieselgeek, dws1230, F250Hoss, fatboy95, flicker, ford97, foxracing0934, franmar_slo, ghostang93, gnxtc2, Harl, HMBUILDER4U2004, INTPSTROKE96, jjmcd, JonFord, Junior, KDM, KMurakami, knoxville, Magnum PD, Matt_P, maverik2711, morefuel, nasty96, NastyCracker, old man dave, oregon96psd, outlaw5.0, ParkerFly, patricku47, pc97f350, pmasterson, psdmike, PSDTECH97, ReconDieselPerformance, Red97, rideracelivemx7, rodeo_man, rpm-inc, Rtxcoon, SNR, stockjeep47, STROKER #1, Stroker96, strokinblue96, TECH51, tella, the great white, Tim @ P.I.S., Tom S, z281le, zak283, zappattack18, zilla68
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
