quick question. After installing the 275 tune into your truck then say you want to switch it to the 210 tune do you need to return your truck back to stock first before going to the 210 or you just up load the 210 tune onto the card.
So i guess the next question would be why cant you just get 2 cards so you can keep one tune on one card and another on the other card. Or is that not possible? (instead of redownloading each tune on the same card)
You can load all your tunes and then some on the cards, then you dont have to switch cards, just leave the card in go to tuning, load stock if you want stock or load tune and then select the appropriate tune.
Theres no need to go back to sttock unless you want STOCK, just switching tunes takes about 15 mins...maybe a couple less depending.
