plan for the worst pray for the best is all i can say.
there have been claims that spartan doesnt leave any footprints and from my experience with spartan...its awesome!!!
yeah do some research but Pahrump who posts on here had his high pressure fuel pump go out. He only had time to download the truck to stock and take it to the dealer. They suspected he had something done to the truck, because he had his intake on still, but even the district rep couldnt prove anything so they warrantied his high pressure pump and there are others who have had issues and warranty has not been denied.
I ahve has zero issues with the Spartan tuner and warranty work....just as mentioned above.
Seems there was a bad seal in my HPFP allowing fuel to drain back into the tank after sitting and the truck would not start after a long rest peroid...I set it to stock and put the CAT/DPF back on, but left the intake and RBP filter back exhaust...along with 10" lift..etc on the truck and thy looked...and looked...and called in a regional rep and he looked, questioned...and frowned..then did $6500 worth of work with the entire fuel system replaced, and the radiator at the same time.
Yes, you have to pull the trucks info and send away for the tunes. If you would like, give us a call tomorrow and we can answer any questions you might have. (919) 636-1518 -Aaron
^^^Cool dude he will help you with anything you need.
