my friend has a 04 with studs,egr delete,banks high ram,exhaust and intake system. He just bought an SCT from Elite and on the insanity tune he is getting 30psi of boost does this sound about right, he gets 24psi without the tuner.
Every truck is different....the exact same tune on 2 different trucks could produce very different results.
You can't just say adding X tuner will make X boost.
Mods, condition, elevation, etc....they ALL make a difference.
i know all that makes a difference but as a rule of thumb 10psi=100hp so 30psi would only be around 300hp. i was figuring he would have gained more than 6psi. i thought it would be around 40psi. what kind of boost #'s is everyone seeing with like innovatives drag tune
Stock is about 25psi +/-. My custom tunes run about 27-32psi.
Boost is only a component of making power. Timing and fuel volume need to be included in the process. If you get it all right, you can have great results...get something wrong and it might not be too pretty.
107.4K members
