I am sure there will be serious repercussions. Today while working on the Ranger, I had something work, without needing to be modified or custom fabbed. I can assure you that I will track down the culprit and there will most likely be serious ramifications for this oversight from the custom fabrication gods.
The power steering line that goes from the superduty power steering pump has the same fitting as the one that is on the Ranger power steering rack.:aiwebs_029::ugh: There is a good chance that I am dreaming all of this, and will wake up tomorrow to find out that they are two completely separate pieces, and there was never a chance that it will fit. That is not all, all 3 hoses fit the reservoir that I have chosen and mounted. Be on the lookout for the 4 horseman of the apocalypse, and beware, lightning could strike at any time.
