My own Grey vs. Black CPS test - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 04-22-2009, 12:17 AM
Pocket
Offline
<-- it's like that
Member's Gallery
I had a chance today to compare the grey and black CPS's side by side, and give you guys some results that you can actually see. I took several pictures showing the size variations, as well as showing the differences in the magnetic strength. The results are conclusive, there are distinguishable difference between the two. Check it out with your own eyes.
First, here are the results of AE and the changes in cylinder rotation. Most cylinders remain mostly the same, however notice the distinct changes in the #3 and #8 cylinders. My #8 drops to zero because I'm running a regulated return and an AD injector instead of an LL. Those with LL injectors probably won't see 0% on #8. I put down the ranges that I saw with each cylinder, with the minimum and maximum values seen after monitoring each cylinder for more than 1 minute each. Engine was completely warmed up each time, with extended drive cycles to ensure that testing was fair and equal.
Grey CPS:________ Black CPS:
1) 0.2-1.2%______ 0.2-0.9%
2) 0.7-1.2%______ 0.7-1.2%
3) 1.6-2.4%______ 0.0%
4) 0.0-0.7%______ 0.0-0.8%
5) 0.0%__________ 0.2-0.7%
6) 0.0%__________ 0.0%
7) 0.0%__________ 0.0%
8) 1.7-2.6%______ 0.0%
The next two pictures show the differences in size. The black CPS is obviously wider than the grey, but if you look closely you can see that it is also slightly longer. For the length comparison, I stood them upright side by side on a level surface so you can see the slight difference.
Now for the last two pictures, I found a washer that was heavy enough that the grey CPS couldn't pick it up off the table, but the black CPS had no trouble picking it up every single time. In fact, the strength difference was incredible, as I could move the black CPS in any direction I wanted and with some force, and the washer wouldn't fall off. The grey one on the other hand could barely lift a corner of the washer off the table, but never could lift the entire thing.
This is all the testing I could think of. Unfortunately I don't have other testing materials such as an oscilloscope to compare signal differences between the two. A while back, Swamps offered to run a test between grey and black CPS's using a cam timing gear, a variable speed motor, and an oscilloscope to see if they could in fact find signal differences between the two sensors. A test like that would verify what many PSD owners have seen with scanners hooked up to their trucks. If they do move forward with that test, I would be very interested to see the results.
On my truck, the grey CPS did not pose enough of a problem to actually trigger a check engine light, or to fail the CCT. However, results may vary with other engines. It is obvious that there is an effect on the #3 and #8 cylinders. Most of the rest remained about the same, with only a small rise on #5 with the black CPS installed.
Right now I am taking a guess that the weaker magnet and slightly shorter sensor has an effect on when the CPS actually picks up the cam timing gear, which would have an effect on injection timing as well. Feel free to discuss or post up ideas or additional information.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the Colorado diesel community.
Reply With Quote Quick reply to this message Go to the top
Old 04-22-2009, 12:36 AM
Bighunter
Offline
Banned
Member's Gallery
Re: My own Grey vs. Black CPS test
I failed a Cont test, and had a idle knock with the gray... replaced without asking while in the shop for a completely differant issue... Thank you Ford for costing me another $40 bucks for a new black...
  #3
Old 04-22-2009, 12:45 AM
redmist
Offline
Member's Gallery
Mine also had an idle knock and fails a CCT on the number 8. I have the gray CPS and will switch to the black..
AE Shows my #8 at 5.0%
__________________
2001 F-250 4x4 Crew shortbox, Optix gauges, DP F5 60towHighAlt, 80E, 100, 120. WW, ITP Boost Annihilator. DIY 6637 intake.
  #4
Old 04-22-2009, 01:03 AM
blowincoal's Avatar
blowincoal
Offline
Member's Gallery
I need to get a black sensor. ford stealership here doesnt have any and the parts guy got buthurt when i tried to explain that the new and improved grey sensor was lighting my CEL.
__________________
2001 F-250 handshaker on 6INCH 35s, TS 6pos Swamped, IDM mod, 7" miter cut stack, foil delete, DIY tymar intake, billet grill, and '05 headlights
  #5
Old 04-22-2009, 01:07 AM
PsdPullerJR's Avatar
PsdPullerJR
Offline
Member's Gallery
Interesting......
__________________
2000 PSD Puller,6" stack, AFE Stage II, Auto Meter NVs, CPR-X Fuel system, H2E, Monster box, Stealth twins, 400/400 B codes, Minotaur software. 2000 F350 CC long box,xlt towing a 2011 Golden 20+5 GN.
  #6
Old 04-22-2009, 04:54 PM
tubular031
Offline
Member's Gallery
What part number is the black CPS?
__________________
01 F350 CCLB SRW
  #7
Old 04-22-2009, 05:35 PM
Aljay's Avatar
Aljay
Offline
Don't EFN worry about it
Member's Gallery
I 'm getting a BLUE ONE ! Makes the truck smoke like hell !
I'll see if I can dig up a part # .
__________________
Overfueled for your pleasure !
  #8
Old 04-22-2009, 05:41 PM
Tom S's Avatar
Tom S
Offline
OEM Moderator
Member's Gallery
I fixed your first post pics with the ones on this site Curtis.
Tom
  #9
Old 04-22-2009, 06:28 PM
Powerstroke Racer's Avatar
Powerstroke Racer
Offline
7.3 PSD Mythology Expert
Member's Gallery
I posted that a while back and Dave at Swamps basically called me an idiot
__________________
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination. Diesel Innovations Online Performance Diesel Products!
  #10
Old 04-22-2009, 06:36 PM
PTSUPERD's Avatar
PTSUPERD
Offline
Banning Smut
Member's Gallery
If the shoe fits.....
lol. sorry had to.
  #11
Old 04-22-2009, 06:44 PM
SMOK'N BLUE STROKER's Avatar
SMOK'N BLUE STROKER
Offline
HHAUL'N STROKER
Member's Gallery
I had my sensor changed out about a year or so ago with no probs. But I have a black one in my door just in case!
  #12
Old 04-22-2009, 07:40 PM
Powerstroke Racer
Offline
Member's Gallery
lol. sorry had to.
http://www.powerstrokenation.com/for...ad.php?t=19108
  #13
Old 04-22-2009, 08:26 PM
Pocket
Offline
<-- it's like that
Member's Gallery
Tom
Thanks Tom, you can go ahead and delete my repost of the pics if you want. For slower connections I don't think people need two copies of the same pics loading.
  #14
Old 04-22-2009, 08:53 PM
dixieland-diesels's Avatar
dixieland-diesels
Offline
owner/president
Member's Gallery
Send a message via MSN to dixieland-diesels
International #1821720c99
__________________
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
  #15
Old 04-22-2009, 08:55 PM
dixieland-diesels
Offline
owner/president
Member's Gallery
The blue one retards the timing,but heres the International part #1807339c92.
  #16
Old 04-23-2009, 02:32 AM
golfer's Avatar
golfer
Offline
fueled by Colecovision
Member's Gallery
I'll see if Jon will scope the CPS signal on his test bench with a gray vs black CPS.
__________________
swampsdiesel.com
toll free 866-595-8724
click to send email
  #17
Old 04-23-2009, 08:32 AM
Stewart's Avatar
Stewart
Offline
Never Fry Bacon NAKED!
Member's Gallery
Curtis, great post!
Rep points to you for....oops, wrong board. My bad!
Stewart
__________________
2002 F250 Lariat SC 4x2
- 38R, AC's, MBRP 4", AFE Big Boost, JW valve body, Riiffraff HPX soft line & CCV, ITP's OBA, Live Tuned by Jody
2000 4X4 Excursion
- John Wood 4R100, AFE Stage 2, MBRP 4", 1.0 housing, WW, F5, V and B code springs, ITP's OBA and pre-pump kit.
  #18
Old 04-23-2009, 11:27 PM
00strokey7.3's Avatar
00strokey7.3
Offline
Member's Gallery
could someone post a DIY for switching out the CPS? I got the grey one and seems like the truck is idleing rough as hell.
__________________
2011 F250 XLT 6.7L PSD CCSB
Proud To Be A "Rightwing Extremist"
  #19
Old 04-23-2009, 11:31 PM
SMOK'N BLUE STROKER
Offline
HHAUL'N STROKER
Member's Gallery
Who hasnt had problems with the grey sensor yet?
  #20
Old 04-23-2009, 11:51 PM
theham1105's Avatar
theham1105
Offline
young and dumb
Member's Gallery
im gonna get the ford place to do the recall swap again just for chits giggles and then ill do the black one. bad idea?
__________________
2002 F250 Lariat 4x4 SRW
Currently:
8.5" procomp lift,
37/13.50/20 Toyo Muds, XD Hoss Bronze Rims
DP 80e 120r 140
JW VB, Racer X TC
DIY intake, 4" straight before RW
Kenwood DNX5120, 2 Kicker CVR10's,
Recon lights all out back
Shocker 540 Train Horn Kit
Custom Wrap by http://www.allaboutgraphicsinc.com
  #21
Old 04-23-2009, 11:58 PM
SMOK'N BLUE STROKER
Offline
HHAUL'N STROKER
Member's Gallery
When I went in for the recall I pulled out my good black one and put in my old one that was going out. Went in and had them do the recall and ment to pull out the grey one but over a year has passed and havent had any issues with it yet.
  #22
Old 04-24-2009, 03:34 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Here ya go.
http://www.guzzle7pt3.com/cps.php
__________________
  #23
Old 04-24-2009, 06:45 AM
00strokey7.3
Offline
Member's Gallery
Thanks man, I appreciate it. Now I just gotta order one of them black ones.
  #24
Old 04-24-2009, 02:12 PM
Swamp
Offline
Sponsor
Member's Gallery
Curtis,
Would you be willing to send me the SAME two CPS's you used in your test?
What I want to do is run those same two units on my test bench and analyze the waveforms with an oscilloscope.
What I have is a 60-2 tooth Eletcromotive crankshaft trigger wheel mounted to a variable speed motor, and a PSD camshaft trigger wheel mounted onto the 60-2 wheel.
There is a MSD pickup on the 60-2 wheel and a CPS on the PSD wheel.
In addition to scoping the waveforms, I plan on comparing the phasing between the gap position on the 60-2 wheel and the PSD cam trigger to see if there is a trigger point (timing) difference between the gray and black CPS's.
I have spent literally hundreds of hours with a scope monitoring injection timing on trucks and have never observed any differences between the two CPS's, nor have we ever noticed any problems or differences on the trucks that come to our shop, but your tests show some very significant differences!
__________________
Jonathan
Early 99 7.3, Gen3 HPOP, 175/146 Inj's, PI converter
Swamp's Diesel Performance & Technology:
Custom 7.3 Tuning w/ Cylinder Pressure Testing
Advanced Vehicle Diagnostics & Troubleshooting
  #25
Old 04-24-2009, 04:04 PM
Pocket
Offline
<-- it's like that
Member's Gallery
Jonathan I sent you a PM.
  #26
Old 04-24-2009, 04:14 PM
Calico5's Avatar
Calico5
Offline
<-Tis the YZ SeasonWOOHOO
Member's Gallery
Originally Posted by Swamp View Post
Curtis,
Hey...how about also including the blue CPS in your testing? I read lots of anecdotal information about the possibility of gain or loss in performance, but no kind of actual testing to prove anything one way or another.
Thanks...
BTW, Pocket: Excellent info!
__________________
Al in SoCal
2000 F350 C-C SRW 4x4 6-Spd
The Usual Stuff: AFE Intake, 38R Turbo, Big IC, Stealth Big oil, Stock AD Smokesticks, DP F5 Chip & PCM: "Live Tuned", Custom Fuel System, Non-EBPV Pedistal , 'T444' CCV, 4" S/S exhaust, Dual "Aussie" Stacks, SB Double-disc clutch
  #27
Old 04-24-2009, 04:25 PM
444-4D's Avatar
444-4D
Online
Caption This
Member's Gallery
Thanks...
DP Tuner has done some comparative testing of the black and blue sensors.
__________________
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
  #28
Old 04-24-2009, 05:19 PM
Motownfire's Avatar
Motownfire
Offline
<----My last CT scan
Member's Gallery
Any idea of what DP Tuner's outcome was on the test ???
__________________
  #29
jroller's Avatar
jroller
Offline
Member's Gallery
  #30
Old 04-24-2009, 05:21 PM
Aljay's Avatar
Aljay
Offline
Member's Gallery
I can tell you first hand the blue cps is not good for a modded truck. Way more smoke.
  #31
Old 04-24-2009, 07:53 PM
golfer's Avatar
golfer
Offline
Member's Gallery
Thanks...
the Blue (DT466e) CPS retards injection timing by ~4deg, as I recall...making the injection event happen late (hence the smoke)...
  #32
Old 04-24-2009, 08:03 PM
PTSUPERD's Avatar
PTSUPERD
Offline
Banning Smut
Member's Gallery
If you need a blue one for any testing.....there is one in my glove compartment......along with a gray one. Dont you touch the other stuff thats stashed in my truck!
  #33
Old 04-24-2009, 08:07 PM
golfer's Avatar
golfer
Offline
Member's Gallery
I guess we'll have to get started working on it after TS...
  #34
Old 04-24-2009, 08:13 PM
PTSUPERD's Avatar
PTSUPERD
Offline
Banning Smut
Member's Gallery
^^ serious though. Take em, cut em up...whatever. They are yours.
  #35
Old 04-24-2009, 08:16 PM
444-4D's Avatar
444-4D
Online
Caption This
Member's Gallery
How would it do that?
  #36
Old 04-24-2009, 08:32 PM
Powerstroke Racer
Offline
Member's Gallery
signal delay
The 2 extra cylinders confuse it.
  #37
Old 04-24-2009, 08:43 PM
444-4D's Avatar
444-4D
Online
Caption This
Member's Gallery
signal delay
Which two are extra?
  #38
Old 04-24-2009, 09:25 PM
ditch_dawg's Avatar
ditch_dawg
Offline
Genius, when I drink
Member's Gallery
Is there a way to do this in the truck? I am pretty sure the portable O-scope from work can log data.
__________________
'03 F250 CC
Truck Pics
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
blip the throttle, and you just changed your "HPOP" oil
put that on youtube
  #39
Old 04-24-2009, 09:34 PM
bbbxcursion
Offline
ARMY bound
Member's Gallery
I wish I ran the blue CPS........
  #40
Old 04-24-2009, 10:10 PM
TrailerHauler's Avatar
TrailerHauler
Offline
Custom Trailer Sales
Member's Gallery
Interesting info!
__________________
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
  #41
Old 04-24-2009, 10:16 PM
Aljay's Avatar
Aljay
Offline
Member's Gallery
No you don't makes for a lagy smokey pig!
Thats was just with stage 1's and a 100 hp DP tuners tune ! I'd hate to see how much more sun "blotter" it would make on a truck with some real injectors not this baby poop stuff (little) injectors I have ...................
  #42
Old 04-25-2009, 12:58 AM
Calico5's Avatar
Calico5
Offline
Member's Gallery
That is what I have heard. But I don't understand how that can be when it's simply a hall-effect magnetic pickup...unless it has some electronics built in it to cause the pulse delay. There are still web vendors selling the Blue CPS as a supposed improvement over the stock one. And why is the "new and improved" stock one causing so much trouble?
It would be VERY interesting to see a scope comparison of the three different CPS's.
Of course, someone would have to have fancy test-bench to run such a comparison (Golfer...)
  #43
Old 04-25-2009, 01:50 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
#3 and #6.
  #44
Old 04-25-2009, 03:13 AM
gracing's Avatar
gracing
Offline
Member's Gallery
along with a black one
  #45
Old 04-25-2009, 03:42 AM
Pocket
Offline
<-- it's like that
Member's Gallery
That's the mystery we are trying to figure out. Yes it's a simple hall effect sensor, but is it possible that there is a "lag" time that can be seen and duplicated based on both the strength of the magnet and distance (length) from the cam marker. I'm sure the actual signal between all the sensors is identical, but if the reaction time between all of them is different, then that maybe that's why we see these engines react so weird with different CPS's installed.
Either that or maybe my own crazy-assed theory is way off. Who knows. It's late on a Friday night right now and I just got back from beating the crap out of people.
  #46
Old 04-25-2009, 04:05 AM
PTSUPERD's Avatar
PTSUPERD
Offline
Banning Smut
Member's Gallery
Forgot about that one. Some people carry a back up CPS.....I carry 3.
  #47
Old 04-25-2009, 12:59 PM
Aljay's Avatar
Aljay
Offline
Member's Gallery
Don't understand the reason why either but it do. Sucks I had a handful of cam sensors and was like well which ones are good an which are bad ? Let me tell ya it sux to have been drinking and have one fail,sucks worse is having to replace it while parked on the side of the road.Seems like for a while (till I ponied up for a new one) the blue one was my ace in the hole,soo its my spare it lives in the glove box with a 1/4 drive ratchet and a 6 point 10 mm deep socket !
  #48
Old 04-28-2009, 01:26 PM
trentdufour's Avatar
trentdufour
Offline
Member's Gallery
OK I found the part number International #1821720c99 but where do I order it from? Is this something I can get at NAPA or ford or autozone? I am new to these trucks but after what I read I want to carry a spare.
  #49
Old 04-28-2009, 03:41 PM
tch.280
Offline
Member's Gallery
You can order that part number from a local International Harvester dealer or you can get F4TZ-12K093-C from Ford. It is the CPS for the 94 to 96 and it is about 35.00 bucks. It will work in any of the 7.3 powerstrokes.
__________________
2006 Dodge 2500 MegaCab, 4x4, Auto, 5.9L CTD
SOLD-2001 F250 Lariat CC SB 4x4 auto, 207,000 miles, linex, DP tuner 40T, 80E, 120R. 3.5 inch DP/4 inch exhaust. ATS housing. AFE stage 1, Hutch and Harpooned, HV IDM. V-10 transmission cooler. Medium build transmission. Baby terminator single HPOP, Turbomaster wastegate, 1.0 exhaust housing.
  #50
Old 04-30-2009, 11:06 PM
SMOK'N BLUE STROKER
Offline
HHAUL'N STROKER
Member's Gallery
Ok so Im starting my own test. Ive ran the grey cps for about a year now and for work I drive 222 miles round trip 3 days in a row. I calculated my mileage with the grey cps and now this week Ill put in the black cps. Ill let you all know what I come up with in 4 days.
Of course this is highway driving at 70 and 65 mph.
  #51
Old 05-01-2009, 12:47 AM
theham1105's Avatar
theham1105
Offline
young and dumb
Member's Gallery
got the ford one and its blue. ? wrong one?
  #52
Old 05-01-2009, 02:12 AM
SMOK'N BLUE STROKER
Offline
HHAUL'N STROKER
Member's Gallery
The blue cps retards the timming if im not mistaken.
  #53
Old 05-01-2009, 02:27 AM
dixieland-diesels
Offline
owner/president
Member's Gallery
Yep you are correct.
  #54
Old 05-01-2009, 03:34 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
A blue one from Ford?
  #55
Old 05-01-2009, 03:42 AM
Cat_Rebel's Avatar
Cat_Rebel
Offline
OBS junkie
Member's Gallery
I remember that day well swapping out the old CPS in my driveway & didn't get the old one 100% tight......(get to dealer & tech comes over to us)
Tech- "Dude there's a huge oil leak coming from the front of your engine I think something is cracked"
Smok'n- "Really that don't sound good"
Tech- "Yeah you boys didn't touch anything lately have you?"
Us- "No not a thing this is news to us" (trying to keep a straight face & keep from smerking & laughing)
Tech- "Well sign here & I added some oil you might want to get that leak looked at soon"
Us- "Ok we will have a good day"
Drive away giggling like a couple of little girls.
__________________
97 F350 CCLB "Da Bus"
RIP Will Iott
  #56
Old 05-01-2009, 03:46 AM
SMOK'N BLUE STROKER
Offline
HHAUL'N STROKER
Member's Gallery
Thats was some funny ass ####! Oil leak? Where the hell did that come from!
  #57
Old 05-01-2009, 04:15 AM
theham1105's Avatar
theham1105
Offline
young and dumb
Member's Gallery
Wink Re: My own Grey vs. Black CPS test
Yes sir. It's a dark blue but blue no less. It's for a 96 7.3. It was $35. I figured thy was better than 180 or whatever for a black one. But I don't wanna retard my already crippled athlete anymore than it is.
  #58
Old 05-01-2009, 05:25 AM
tch.280
Offline
Member's Gallery
Would you say like a dark purplish in color? If so that is the new "black" one for the OBS from ford. The only black ones you might find are old inventory from Ford.
The IH blue is a pure blue color and it is the only one that retards timing because it is for a 6 cylinder engine.
  #59
Old 05-01-2009, 12:05 PM
lainemech
Offline
Member's Gallery
Hey everyone,
I'm new to PSD's. Ya'll have me a bit confused on these CPS's. There's black, purple, a couple different color blues, a grey one, one for an International 6 cyl (dont know why you would want a 6cyl part in a 8cyl) and one for OBS's.... Sheesh, what CPS do I need for a 100% stock 99 F250 7.3 PSD, that it will run correctly with? And, again where is the best place to get it (the right one)??
Thanks in advance,
Bob
  #60
Old 05-01-2009, 12:35 PM
TrailerHauler
Offline
Member's Gallery
you would want, according to pockets results a black one. Right now most are running either a black or grey one. I beleive you can still get both from either an IH dealer or Ford.
  #61
Old 05-01-2009, 12:55 PM
dixieland-diesels
Offline
owner/president
Member's Gallery
  #62
Old 05-01-2009, 03:09 PM
theham1105's Avatar
theham1105
Offline
young and dumb
Member's Gallery
Yea it's a really dark blue. So I got the right one?
  #63
Old 05-01-2009, 04:05 PM
Calico5's Avatar
Calico5
Offline
Member's Gallery
Like this, or darker...blueish/purple??
  #64
Old 05-01-2009, 10:05 PM
theham1105's Avatar
theham1105
Offline
young and dumb
Member's Gallery
Darker. With a silver metal part. I just put it in and it doesn't seem to have fixed anything
  #65
Old 05-02-2009, 02:42 AM
SMOK'N BLUE STROKER
Offline
HHAUL'N STROKER
Member's Gallery
I went to the IH store yesterday to see if they had any black cps left. They said yea and they said they had 2 of them.
So sure as #### I was going to get both of them but when he brought them out take a wild guess what color they were?
Thats right GRAY! Oh and they swore it was the black one1 FN dumbasses!
  #66
Old 05-02-2009, 11:21 AM
dixieland-diesels
Offline
owner/president
Member's Gallery
Damn,better luck next time.
  #67
Old 05-02-2009, 07:41 PM
redmist
Offline
Member's Gallery
So I am running the gray CPS now and fail a CCT on the number 8 and sometimes the number 2 cylinders....
I also have a knock now at idle!
going today to International and getting the black.
  #68
Old 05-02-2009, 10:33 PM
theham1105's Avatar
theham1105
Offline
young and dumb
Member's Gallery
so the "black" one i got is better but hasnt fixed anything.
  #69
Old 05-03-2009, 10:42 PM
blowincoal's Avatar
blowincoal
Offline
Member's Gallery
got a black one from IH dealer yesterday, it was labled with a grey part number and the black ones got deleted out of thier system so i got the black one for grey price $19.55 ... fault code gone since, fingers crossed.
  #70
Old 05-05-2009, 03:56 AM
SD01WD's Avatar
SD01WD
Offline
William
Member's Gallery
The "black one" (like really dark blue) is what IH sold me today
P/N 1876736C91 said it was latest update...Thats my back up.
Aljay I have nice new "gray one " for your smoker!
__________________
2001 SD 2 wheel drive
DP tuned by Scott @ TNT of CC
ITP Regulated Return/ in tank & prepump mods: When Only the BEST will do!
Tank has been harpooned
Gages: Boost and Pressure
on the post & 4" S/S turbo Back by Aljay.
Rancho's all around
  #71
Old 05-05-2009, 04:00 AM
dixieland-diesels
Offline
owner/president
Member's Gallery
How much did it cost?
  #72
Old 05-05-2009, 01:20 PM
SD01WD's Avatar
SD01WD
Offline
William
Member's Gallery
It came to $29. and change. I guess I didn't get the Gray or buddy
deal.
  #73
Old 05-05-2009, 01:22 PM
dixieland-diesels
Offline
owner/president
Member's Gallery
Sounds real cheap for an International cps.
  #74
Old 05-05-2009, 01:24 PM
SD01WD's Avatar
SD01WD
Offline
William
Member's Gallery
Well Box even has "Navistar, Inc." on it and Henchon (made in)
Mexico . PLease don't tell me I got had...
  #75
Old 05-05-2009, 01:30 PM
dixieland-diesels
Offline
owner/president
Member's Gallery
All of my black cps boxes say,INTERNATIONAL,made in the usa.Nothing about Navistar?
  #76
Old 05-05-2009, 01:54 PM
SD01WD's Avatar
SD01WD
Offline
William
Member's Gallery
Guess I've been had by the IH dealer, hope it'll get me home if
it comes down to it! It even has the PN stamp in it. Second
look at box and it does say International in big white letters.
The Navistar is small white letters on lower side.
  #77
Old 05-05-2009, 01:59 PM
dixieland-diesels
Offline
owner/president
Member's Gallery
Let us know how it works out.
  #78
Old 05-05-2009, 03:07 PM
Calico5's Avatar
Calico5
Offline
Member's Gallery
"Navistar" is "International Harvester"...same company.
I believe all of the "factory" CPS's are made by Navistar/IH, the Ford ones are just repackaged. When I replaced my CPS a couple of yeas ago, I got it at a Ford dealer. It was the black one (and it cost a bunch!). It was in a "Ford" bag, but the CPS itself had both "IH" and the IH part number on it. I'm also pretty sure it was "hecho en U.S.A", IIRC...lol
I believe now, though, that some of the parts may be made and marketed by other companies.
  #79
Old 05-05-2009, 03:37 PM
Big Bore's Avatar
Big Bore
Offline
Keyboard Thug
Member's Gallery
Is this they one they will put in my 96 to honor the recall?
__________________
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
  #80
Old 05-05-2009, 03:55 PM
Big Bore's Avatar
Big Bore
Offline
Keyboard Thug
Member's Gallery
BTW Curtis, I have a blue CPS if you want to do a test. In fact I need to get another black one for my 96 to replace the current blue one in it. I think I have two blue spares in addition to that one. Fell for the pretty advertising again.
  #81
Old 05-05-2009, 09:16 PM
SD01WD's Avatar
SD01WD
Offline
William
Member's Gallery
Hey guys, did I get the wrong PN for a 2001 7.3???
PN 1876736C91 is what they laid on me. Or it the same
for all 7.3?
Thanks
  #82
Old 05-06-2009, 02:26 AM
dixieland-diesels
Offline
owner/president
Member's Gallery
Yes i know International & Navistar are the same co.,but he said his was made in Mexico?
  #83
Old 05-06-2009, 02:29 AM
dixieland-diesels
Offline
owner/president
Member's Gallery
for all 7.3?
Thanks
I'm not saying the one you got wont work,but the black cps that i and most folks want is INTERNATIONAL #1821720c99.
  #84
Old 05-06-2009, 03:12 AM
SD01WD's Avatar
SD01WD
Offline
William
Member's Gallery
Well I guess I got "HAD"... I'll have to find an other place to get
the right one. Thanks for the help to show me the WAY!
  #85
Old 05-06-2009, 04:10 AM
tch.280
Offline
Member's Gallery
If the 96 is included in the recall then yes, I can't remember if the 96s were included?
  #86
Old 05-07-2009, 01:04 AM
Torque37
Offline
Member's Gallery
Didn't Jody have these listed on his website?
__________________
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
  #87
Old 05-07-2009, 06:48 PM
Pocket
Offline
<-- it's like that
Member's Gallery
Yeah but when I checked with Diane the other week, they were out of stock.
  #88
Old 05-10-2009, 02:47 PM
camojeeper's Avatar
camojeeper
Offline
Moddified by me
Member's Gallery
nice curtis
  #89
Old 05-10-2009, 03:19 PM
Bushwakd's Avatar
Bushwakd
Offline
Edward Scissorhand WanaB
Member's Gallery
Any idea where the black International CPS #1825899C93 fits in all this. I bought this from Powerstrokeshop.com back in 2002. After Ford did the recall (grey) on my truck I pulled the grey cps and put my International one in. I just found another black International #1825899C93 as a spare. Is this an older version black or what? Is the one I have the correct one???????
__________________
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
  #90
Old 05-11-2009, 08:15 AM
4cstr's Avatar
4cstr
Offline
Member's Gallery
I had this discussion with my IH parts guy a few months ago. IH is OUT of their supply of black sensors. There may be a few dealerships that still have some left on their shelves...but nationally...they are out. The part number...1821720c99 now rolls over to the grey cps.
If you are lucky enough to stumble across a dealer that has a black one on the shelf...get it. I know that NAPA carries a black one...I don't know the part number. I have heard mixed results about that one though. Some report good things...others report that its a piece of crap and good for nothing except a paperweight.
__________________
early 99, old, slow but paid for.
  #91
Old 05-11-2009, 02:00 PM
dixieland-diesels
Offline
owner/president
Member's Gallery
I've always bought mine from Jody@dp tuner,but there out of them.
  #92
Old 05-11-2009, 09:19 PM
Bushwakd's Avatar
Bushwakd
Offline
Member's Gallery
This link is not directed at any one individual, so no flamin. Look at the part #'s for the International CPS listed in the link. Is there a right one and a wrong one? Or it does not matter. Several of you have posted the 1821720C99. Match that # to the # in the link. I have always for years wanted to know why the difference in the #'s. If somebody could cross reference the #'s in the link from Ford to International we might get somewhere and I can bury the dead horse.
Can we keep this civil? To me I see it as the C99 # should go to the 99-03 and the C93# should go to the 94-97 but the info shows different. I am running the International 1825899C93 and also have a spare.
http://65.121.190.196/mods/cps.html
  #93
Old 05-11-2009, 10:39 PM
Calico5's Avatar
Calico5
Offline
Member's Gallery
A couple of years ago, when I replaced my CPS (with an International one), I told the IH dealer I needed one for a T444e engine. The dealer said he needed to know the engine serial number. He basically said there was any "early" and a "late" version of the CPS for the 444.
I'm sure this coresponds to the "early" and "late" version of the Powerstroke as well.
  #94
Old 05-12-2009, 08:26 AM
4cstr's Avatar
4cstr
Offline
Member's Gallery
The following comes directly from my IH guy...who I trust quite a bit.
The base number for the cps is the 1821720. This is the last base number for the sensor. The Cxx number stands for the iteration of said part. So...C93 was the first version of the part...with C99 being the last iteration of the part. He told me that sometimes the only reason a part number changes is because something else changed with the motor. So...the part physically stayed the same...but the part number changed.
According to him...there is no such thing as an "early 7.3L" cps versus a "late 7.3L cps". The sensors are completely interchangeable with the motors. If you have a cps with a part number 1821720C93...it is the same as a cps with a part number of 1821720C99. One of the first ones I got from him was the C93 version. It ran fine in my early 99. The last one I got from him (I have 3 new ones stashed away ) was a C99 version. I installed it and the truck runs just the same. No difference from what I could tell.
He was also the one that did a national search of the IH version of the cps...and told me that nationally...there are no more.
  #95
Old 07-11-2011, 08:13 PM
mudtireman
Offline
Member's Gallery
I know this is an old thread but I just found it in an online search. Just this morning I had to get a CPS so I stopped at my local IH dealer and he sold me IH # 1821720C99.
Did I luck up by getting this? What I've read here is that these no longer exist.
Is this the correct CPS for my 96 7.3? The truck is running, but doesn't seem "right" for some reason. I've also read that maybe these older sensors won't work as well if you have a programmer on the truck, which I do.
Thanks
  #96
Old 07-13-2011, 03:30 AM
Tubbed440's Avatar
Tubbed440
Offline
Member's Gallery
If the sensor is magnetic, it's not a Hall Effect sensor, it's a VR sensor, or variable reluctance. The only way a hall sensor would work in this case is if there were magnets attached to the cam gear.
At any rate, if there is a difference in the actual magnet used in the sensor, then it will have a change in output of the sensor, unless there are built in electronics (signal conditioning) in the sensor itself. Also, a VR sensor is somewhat sensitive to installation clearance, or how close it is to the actual gear or wheel. The farther away, the less signal strength. I could see in some cases with a weaker magnet, a mounting bracket and engine block that were at the opposite end of the tolerance spectrum, that the signal may not be "within spec" for the computer.
I would like to see this test done as well, seeing as how today I just had to change my CPS out due to my truck going into what seemed to be a "limp mode" and hardly idling. I replaced with a grey aftermarket sensor, and it's back on the road again. I don't know if it's the fact that I read here today before I replaced the sensor that the grey one lowers performance, but I could almost swear it seems to be down on power. It does idle quite well though.
__________________
99 F-350 Dually 4-door - Bone stock for now.
  #97
Old 07-13-2011, 12:49 PM
Tubbed440's Avatar
Tubbed440
Offline
Member's Gallery
Update from this morning. I'm thinking the Grey vs black in may case is the placebo effect. Power seems the same and the mileage computer is right on target. Time will tell on the mileage aspect as I'll need to drive it for a week and do a hand calculation. This morning when I filled up, I hand calculated it to be 18.0 mpg vs the computer saying 17.2. Close enough IMO.
  #98
Old 08-04-2011, 11:34 PM
Highstyles_john's Avatar
Highstyles_john
Offline
Member's Gallery
I ran a black cps till it started to go. Got a grey one from ford and it ran fine for a while. Then run the test and number's 3 and 8. Changed it to a black today and it runs better. I still have to take it to have the test run again.
__________________
E99 F250 Stock 7.3L 6 speed 2008 step tailgate 2008 rims Superchips no cat
  #99
Old 08-05-2011, 12:14 PM
Tubbed440's Avatar
Tubbed440
Offline
Member's Gallery
I'm having a hard time even finding a black one - for a reasonable price. Still running the aftermarket sensor at this point. Doesn't run as good as it used to, and the mileage seems to be a little lower.
  #100
Old 08-05-2011, 09:10 PM
CGMKCM's Avatar
CGMKCM
Offline
Member's Gallery
Riff Raff and Diesel O-rings.com had a couple left each as of last weekend.
__________________
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
  #101
Old 08-05-2011, 11:24 PM
94.5PSD's Avatar
94.5PSD
Offline
Member's Gallery
My truck is hard staring, rough/shack idle and no power. Truck has new #4 injector and as of yesterday new idm and injector harness and gaskets both side truck still runs like crap. Truck failed contribution test today, #3 & #8. I was going to replace 3 & 8 injectors but after reading this, do I just need cps?
__________________
2008 F250 CCSB 6.4 EGR Delete, 4" Straight 6" Tip, Spartan tuned
SOLD E-1999 F350 CCLB 7.3 6 spd Ranch Hands F/R, TS 6 pos custom tunes, 6637, 5" Straight, 8" Rough Country, 38x15.50 20x12's
Gone:94.5 F350 5 speed, 35x12.50x18 Trail Grapplers, MT 18" classic locks, 6637 intake, 6 pos chip, 3" DP to 4" straight, Autometer C2 Pyro/Boost, Stage 2's
  #102
Old 08-05-2011, 11:29 PM
Wideopenpowersports
Offline
Member's Gallery
Anyone have any idea in regards to a 7.3 that has developed all of the sudden a need to not start or die all at once while driving? I installed new fuel filter and checked that the pumps are working and also installed a new CPS today. With that being said, it will fire right up sometimes and run for an hour or so but then will not restart.
  #103
Old 08-06-2011, 06:49 AM
TARM's Avatar
TARM
Offline
Member's Gallery
Have you run a scanner to check for soft codes yet? If not that should be the first thing you do. You can swing by a PEpboys as they have scanners with the Ford sensor package or pick up AE.
Of things it could be a IPR or HPOP itself. You could have a cam gear walking and causing lose of signal with the CPS
Way to many things so first check codes to see if it points you in any direction.
  #104
Old 08-06-2011, 04:37 PM
Wideopenpowersports
Offline
Member's Gallery
I ran a snap-on code reader and no codes where present. This morning the truck fires right up. After running for a period, it then will not start. Also, checked all fuses and all were good. Also, should the tach move even with a TS chip?
  #105
Old 08-06-2011, 05:52 PM
powerstroke cowboy's Avatar
powerstroke cowboy
Offline
Running at last...
Member's Gallery
yes your tachometer should move When cranking. A Chip will not keep it from moving.
Is it a chip Right from TS or is it a TS style chip???
__________________
97 CCLB 4x4 ZF6 99@15.7
  #106
Old 08-06-2011, 05:55 PM
Wideopenpowersports
Offline
Member's Gallery
It is from TS but a friend of mine wrote the codes. I have had it on the truck for 8 months or so.
  #107
Old 08-06-2011, 06:38 PM
powerstroke cowboy
Offline
Running at last...
Member's Gallery
That could be the trouble. right there. Depend on who you "friend " is. But you say it will not start back up?? Does your tachometer move when cranking???
  #108
Old 08-06-2011, 06:54 PM
Wideopenpowersports
Offline
Member's Gallery
The tach never moves. I don't recall it ever moving though. But apparently it should huh? I did replace the CPS with one from Autozone. Maybe that is a mistake because it is a grey.
  #109
Old 08-06-2011, 06:57 PM
Wideopenpowersports
Offline
Member's Gallery
As of right this moment, it will start up perfectly fine but after a very short drive " 1 mile or so " it will die and not restart until after an hour or so. Last night it wouldn't start up at all but yet this morning, it fired right up and has 20 times today but I am afraid to drive it until I know it is correct. Have towed 3 times in 2 days.
  #110
Old 08-06-2011, 07:14 PM
powerstroke cowboy
Offline
Running at last...
Member's Gallery
Go to Ford and Buy a CPS from them. The tachometer should ALWAYS move when cranking. Your CPS is not working right. The Black CPS is better BUT The gray one is about 25 to 34 dollars.
In fact i have like 7 or 8 NEW gray ones laying around.
  #111
Old 08-06-2011, 08:00 PM
Gotti2k7's Avatar
Gotti2k7
Offline
F250 Black Cloud Edition
Member's Gallery
Most likely, this is a IPR issue. Not a CPS. Make sure the tin nut is snug on the the back of the sensor. And that the solenoid part is not moving around.
__________________
02 F250. Turbonetics, SRP1, Tim from P.I.S built Hybrids, Built Trans, Afe Stage 2, HPX line. Tuned by Jonathan from Beans, 4 inch exhaust, with the muffler. Triple Phantom 2 gauges. Forged Rods and with another block. 500hp.
  #112
Old 08-07-2011, 01:47 PM
94.5PSD's Avatar
94.5PSD
Offline
Member's Gallery
Cps was fine, deffenitly needs #3 & #8 injectors which will get replaced this week
  #113
Old 08-08-2011, 05:38 PM
speeddemon31176's Avatar
speeddemon31176
Offline
Demon Dually
Member's Gallery
That sounds like the phantom codes you get with the light grey cps from ford. I wouldn't go changing injectors yet.
__________________
Human Verification
(View-All Members who have read this thread : 771
00 7.3, 00strokey7.3, 01excursion7.3, 01powersmoker, 01stroke, 01strokercc, 01strokin, 02 7.3, 02bestroked, 02BigD, 02F350, 02psd, 03_PSD, 06powerstroke, 16yrenthusiest, 1995stroker, 1badpsd, 1badz, 2000XLifted, 250turbo, 2jzpgt, 35thls1ss19, 389SixPack, 444-4D, 4ds4me, 4duggan, 4wydnr, 6.0cj7, 69800, 7.3 Rocket, 7.3 Stroke, 7.3Havoc, 7.3pokesfan, 7.3_STROKE, 73stroke99, 806bob, 82crawler, 84crewcab, 86lxnotch, 88 gtu, 91blackshortbus, 91turbogsx, 94.5PSD, 94powerstroke, 96 greenstroke, 96 stroker, 97rattlebox, 97strokeonit, 97strokn&smokn, 99F250Smitty, 99powerstroke350, 99whitestroker, Aaron S, aaronbob, abbottfarms, Acehop, ackdog, ADubDiesel, ajfetterman, AK1, aklim, Al Mighty, AlaskaRedneK, almostfinished, AMB, Aminator, Archery Hunter, arcticatdan, arcticman18, Arisley, ATRdriver1, ATVFREESTYLEKID, aussiedave, Austinj427, awehrmann, AzPsd55, AZPWRSTROKER, badblack01gt, badford350, badluck_early99, baggedbug, bandit67, Barnbuilder, Bartman, bazdog1, BBottoms, BDS, beantown, bergpsd, Big Bore, bigblak250, BigBlue7point3, BigboyF350, Bigcat350, Bighunter, BigJake, bigjake0524, BIGLARRYS03, BigRed97, bigrngyj, bigshawn, bigwheel, big_stroker, BILL.B, bill4d, Binder man, birddog55, birdog, bknight187, Black Beauty 7.3, black cloud 02, black-smoke, Black04Ram, blackie375, Blackmax, BlackPearl03, black_pstroke, Blowby, blowincoal, BMac, bng305, Bockhold, BoilermakerSteve, Boomer, BoomerL37, Borsky, BowHuntinFever, breyrw, BROCKDIESELDUDE, brokexj, Broncoboy79, brooksbronco17, brucem, bryan.d, buckarootrucker, buckingbrutus, Buford-61, bulldog01, Bumpin, Bushwakd, ByrdDog, C C 350SD, c.salt, cadd, cahill24, Calico5, cantrellc123, Capricious, Carolina444, carrj66, caseih7010, casper7.3, caspower, Caster, cat45, CATdiezel, catsnw, cavitation, ccf350stroker, ccrowd, Centxdiesel, CGMKCM, chappy, CHevDog1, cheysays7.3!, Choupique108, Chow Wayne, chrashd, chris1978, chris41, chrisreedtn, Chuck B., chunkdunker, cj45lc, clackclack, CLIFORD3, Codydiesel, COFG-28, coldair, Colorado, Constantfix, Cool Canuck, CooterBrown, Cory_S, cota, Country, cowboy_dan, CrawfishPSD, crazycruz257, Critical, crowz, CtG, CUMMINS_KILLA99, cvdenson, cwprosser, d21067, D2HP, damons250, dannanw, Dantheman, darkside708, daryl4412, Dave, dave186, dave96psd, David N, dblamp, DcMoore999, ddown, Denver, Desert Rancher, deuce-ski, diesel fanatic, Diesel Mack, Dieselboy, DieselBrad, dieseldee, diesellee, dieselman47, dieselmandustin, DieselPower1966, DieselStroke, Dieselsvt, dieseltec192008, Diesel_Dust, DIRTBIKEZ, ditch_dawg, dixieland-diesels, DIYMechanic, dkrajcovic, dmd, DMDP, Doakster, Dogdare, donj1977, double-s-diesel, doubledoor, doubleshot, douger0500, DRD, dstruble, dually4by, duncan351, Dusty Roads, Dynx, e444, Edroe, Eford00, ELKHUNTER, Eric, Eric L, ericyr6, EXCAV8TER, F-127, F-350, F250Hoss, F350-6, F35099, Fade 2 Black, farmall99, farmboy1432, fatsix, fazt201, fbilly420, FDNYret, Ferd Killa, Fever, fhanrahan, Firedogbme, firehog2, Firehunter, fishstick, fishyPSD, fiveohpatrol, Fl Stroker, FleetMan, ford03six0, ford7.3sd, Ford850, fordboy424, FordCowboy, fordman2121, fords4life, FordXtreme, FordyChase, Forged01, frashdog, freshman, FuturePharmD, fyrehose, geargrabbin97, genuineford, george german, Gibrid4x4, glovemeister, gnxtc2, godzillas dad, golfer, Gooch, goodstktbo, Goose1995, Got Diesel, Got4wd, Gotti2k7, gracing, greenbeast, greenlion, GreenScrew, Greg373, guzzle, handsome, harley1rocker, haulin99sdp, Hawkav8tor, Hawnpowerstroke, hazardiz, hcwt, HD Guy, hdchopfather, Headcase98002, hienergy557, Highbeam, highfive, Highstyles_john, hilljack33, HMBUILDER4U2004, hoist00, Holleran, honeyshucks, hookin78, HotRodTractor, houtxfdcapt, hrc200x, Htrn38, Huffboy, hyrk, iamnonstop, ih1947kb3, ihackenberg1086, IL7.3 Powerstroker, Illinois7.3, ironworker25, jake1086, jake2far, jamisgood, jamponyexpress, jarz, jaybuller, JB017.3, JCart, jcmagone, jebbesen, JeepPuller, jello, Jeremy, jeromejcp, JerseyJim, jesserrr99, jetdok2r, JetskiMark, jherzing110, JHill, jhyder408, jimiii, JMF350, jmt1975, jnewberg3538, Jngreen, joediesle, joeford302, Joey7319, johnday, JohnnyBeGood, John_DeereGreen, Jomax, Jordy53, Josh2021, Joush, jroller, JSchuricht, jt1028, jtaylor115, jtbowen31, JToy, ju015dd, justin1889, J_F250, Kahmke, kainers, kampinguru, Kampy, KansasStroker, kawa, kbmkviii, keblmo, Kevinwatts, kevlar3058, kgb, kidder, kilapapipa, kip4234, Klutch, kpasichnyk, KPSquared, krafty, krankin, ktoddford, kvn555, kxexvxixn, kyle43335, Kyle_KleinSS, L10, lainemech, Layson, leakingdieselturbo, lehi, leoneo01, li'l tugger, locrwln, loner1, LoneStar7.3, LongGun_LeRoy, losfinch, loudmouth, MacDinho, machete31, MadMax'97PSD, madmaxz, MagKarl, mandkole, Mark J., markt, markyt, mars1952, Martin #6, Matt-F350, mattgw86, matthewd11, mattr66, mattrac, mattymx, Matt_P, maxndozer, mazdaparts, mbg75, mddevore, Mercracing, metalphd, mg5000, Michigan37, micky_blue, middlemanjw, milehighstroker, MILFORD, Millerfarms, mimetic, mjones, mooseracer96, morbeeeus, morefuel, Motownfire, Mr. Bob, Mr.Franko, mr01000101, mrdoug, Mr_Andy, MSdiesel83, mttrucker, mudguy, MudSouth, mudtireman, mustang_gt_350, nadekeys, nasty96, nasty97, nchappy, Nelly, never enuff, neverkickn, NevrKnow, New6.0PSOwner, Newman, newmexicocrawler, Nick Banos, nickPSD, nicktb, nine54, nitrowarrior, njjeep, nm351, no-tel-in, NorCal997.3, norcalsig, Northcountrywood, Nuttin up, OhioRiverCigarette, Ohnny101, Old OutLaw, oldbluef250, ole_blu, ono_55, orchard6, otterhound, OUTLAW101, outlaw5.0, OverkillMotorsports, OzPowerstroker, ozzy 2002 psd, panhandle_redneck, papaschoo, ParkerFly, Pdt1081, Petro, PHPDiesel, pickit, pjwoolw, Plowboy93, plug ugly, pmasterson, Pocket, powerstroke cowboy, Powerstroke Racer, POWERSTROKE03, powerstroke742008, powerstroke95, powerstrokenstang, PowerstrokeR00, ProF100, projoe86, ProPistols, proshadetree, PSD POWER007, PSD-350, PSDfan99, PSDfreak, psdmax, PsdPullerJR, PSDTECH97, pstk5088, PStroked444, pwrdbyspuds, R.J., RA3PSD, ralph, Raul@stealth-automotive, rcooper919, rdh54, red95psd, Red97, Redfish, Redman84, redmist, redram86, redrocker, renyren, res0wc18, Rescue48, retired jeeper, Reubine, rich, rich in co, RichWT, Ripsaw, RLSCOAL, Rmartin-97, roberth58, Robert_H, robr1970, Rockcrusher, RockinJW, Rockyardjo, Rodknocker, Ron's power stroke, roughneck0913, rpenner54, rpm-inc, RTA-Diesel Perf, runwaypark, Rustin, rusty1161, Saber123316, sagebel, salprofish, samdust, San Antonio 78, savvy1, scheidt27, Schneider 86, scott037, scotts77, scro, SD01WD, SeeYa, semomotorsports, Shaw, shock, SIC-E, sick97psd1, silverslug, simpleman, SINNER, SIR-STROKEALOT, sirnunya, Six-Ohh, sixiron, sjdiesel, Skew12, SKINNER, skyhigh2000, slayer7712, slick_fork, SLO DZL, slowduty80, slowleak, slow_strok'em, smokindiesel2, smokinstroker92, smokyred, smorris, snapon66, sniper_101, Snowman269, SouthFlstrokin', southmike, Southpaw, speeddemon31176, speediseverything, Spyder1100, squeak12, SS496, ssaulnier, steinerr, SterlingStroker, Stewart, stewartte, Stiletto6.0, stoney126, Strictly Diesel, Stringer Driver, Stroke00, stroked, Stroked383, Stroked550, Stroked95, strokefreak, Stroken7.3, strokeorcroak, strokepower, Stroker02, stroker93, strokinhoosier, stupedasou, sturbo90, Suns_PSD, superdutyfarmer, superih, suprhlr, svtdiesel, SWVa, swvaexcavator, SyN, SZYD, tacperformance, Tampa450, tank, tank23, TARM, taterthedog, tayloet1, tbolt, tch.280, Tedzz, TerminatorEngineering, texascadillac42, texaspowerstroker, The Struggler, thebrown, THEDIESELMAN, TheDirt, thedodd, theham1105, thehydroseeder, theSLEEPER, tholt34, Thomas7.3psd, Tim @ P.I.S., Tim Gott, tkdbf350, TNR, toddg, Tom S, Toms014x4, tomspear, TomzToyz2, toolmangary, Torque37, Toybreaker, TrailerHauler, tree trimmer, trentdufour, treyloco, TSGS69400, Tubbed440, tubular031, turboaz2, turbodiesel_02, TurtleZ, two-rocks, TxFire, tycham, Tygen1, TylerDurden, upinsmoke70, utahstroker6.0, vader's fury, vapstroke, voodoomaker, Vozar, Vug, wadeclinton, wampaku, webb06, Wes3328, Wheels, WHITETHUNDER, whitjo, wicked027.3, Wideopenpowersports, widieseltech, wildjon, wildstang3, Woodnthings8, wooner, worktruck6.4, wynndaddy, xray88, xtreme radial, yobuda, yogr, zaairman, zabeard, zarrinvz24, Ziggy, zilla68, zx800x
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
