They add about a 1" I think. Not sure on ride. I used "OBSWIZ" has an adviser on what to use for what I wanted so if you guys have any questions he is a good one to talk to.
You will need at least a 3" rs kit and 4" Icon springs to match 8" rears..no block. You will get a better ride though with Icon 5" rears and a block. That high will require 2 new driveshafts and crossover steering to do it correctly.
How did you do the rear lift? I'm glad I found this thread cause I was just fixin to ask you to post some pics so I can see how it is done. Those are V codes in the front? How do you tell by the stamping which springs you have?
Thanks
It looks great!
LW
Look close, they are two different trucks. One is said to be correct and the other incorrect. full wrap or not, if the bolt breaks or comes out, it's gunna be a mess.
Well using EX springs should be close to retaining that and since the OBS is lighter it should work and ride nice. Only one way to find out. FYI, the V codes will raise a EX aprox 2" so using a RS kit and Ex springs in the front should only geta 1" lift overall.
