im looking at buying a truck, he has on the add there are helper bags out back im assuming that they are air bags to help the rear leaf spring? and if im right is there a compresser that comes along with it?
There could be a compressor on board or if not most guys will put the air valves on either corner of the liscense plate at the back for adding or removing air pressure fro the bags. Same fitting as a tire valve stem so you use an air chuck to fill them.
or you could just have the firestone or comparable bags that dont use air its just a solid rubber bag.
