hi I hope someone can help, 2004 F350 6.0 when stoped has no oil pressure when moving has oil pressure as normal, changed oil and sentinal still same trouble, it is a little harder to start after trouble started, but still starts no knocking in motor when stoped I hope someone will reply
thanks for any help
Hi, yes i can but maybe telling you will also help, I removed the sending unit that is on top of motor behind the oil filter canister and screwed the gage into it.
thanks for your reply
there was a guy on another group, his stc fitting was leaking so badly it was actually effecting his oil pressure. If you have an 05 or newer it is something to consider. if it is a pre-04 then it is possible the pressure relief spring in the lpop has started to go or the lpop is going. I would find the issue as soon as possible. Your pressure is low, you ideal would like to see at least 10psi per 1k rpms.
I thank everone for the advise however it has still not answered my trouble does any one know any other sights that mechinics are on discussing 6.0 trouble
Thank you I will check both, Do I check presure or remove the part
