Coolant Additive For 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto Escrow
Thread Tools Display Modes
  #1
Old 03-13-2009, 05:34 AM
mattr66's Avatar
mattr66
Offline
Snake Oil Salesman
Member's Gallery
What additives other than the one from Ford works for keeping the injector cups happy when refilling the coolant? Doesn't Napa have one called something like napacool or something like that?
Thanks,
Matt R
__________________
Matt Robinson
Gearhead Automotive Performance
Information on My Ford Tuning (Gearhead Automotive Performance)
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
Reply With Quote Quick reply to this message Go to the top
Old 03-13-2009, 08:37 AM
krankin's Avatar
krankin
Offline
Member's Gallery
Re: Coolant Additive For 7.3
I think your thinking of Nalcool. I dont know if it does the same things as the additive from Ford or if they have two different purposes The Nalcool is a water treatment that prevents cavitation erosion, mineral build-up, etc.
__________________
Kevin
00 F250 7.3 Ex Cab LB, 6-spd, South Bend Con-O, DP Tuning, Casserly 230/80% Hybrids, GTP38R, Reg. Return, AutoMeter Boost/Pyro/Fuel Press, MBRP 4", Napa 6637, ITP OBA, 04 Headlights, Ranch Hand Rear
04 F250 6.0 CC SB, SCT with tunes by Elite, MBRP 4", Isspro Boost/Pyro, Warn manual hubs
92 Bronco
75 Jeep CJ-5
  #3
Old 03-13-2009, 10:44 AM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Yes. Napacool. is what you are looking for. think you need 2 bottles. just read the back of the bottle
__________________
  #4
Old 03-13-2009, 01:17 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
I got mine from International, no clue what they call it.
__________________
  #5
Old 03-13-2009, 01:21 PM
bigwhite7.3stroker's Avatar
bigwhite7.3stroker
Offline
Dirty South Strokers
Member's Gallery
I use Napacool seems to be some good stuff we put it in all are equipment also
__________________
TN BB, 238cc's, 910's, Bellowed Up-pipes, Non-EBPV Pedistal, built tranny, Traction Bars, 4.56's, 6.0 IC, Water/Meth,Jody's Tunes
Taylor
  #6
Old 03-13-2009, 01:36 PM
Rustler
Offline
"mad cow" member
Member's Gallery
Thanks,
Matt R
DCA4 is recommended for our cooling systems.
Any good name brand DCA4 is equivalent to or at least a substitute for Ford FW-16, IIRC the new name VC-8.
You need to use Fleet guard 3 way test strips to accurately measure and keep a chemical concentration of 1.5 - 3.0 UPG in the cooling system at all times.
DCA2 is not recommended for our cooling systems and shouldnít be used..
You could use good quality ELC and do away with the use of DCA4 and the testing.
An organic acid is used in ELC and is not compatible with the conventional SCAs so pick one method or the other and stick to it.
Thorough flushing of the cooling system before changing to an ELC is a must.
__________________
01 F-250 CC 4R esof PMT AIS, pine tree air freshener,
some other stuff not worth mentioning .
  #7
Old 03-13-2009, 02:23 PM
mattr66's Avatar
mattr66
Offline
Snake Oil Salesman
Member's Gallery
Cool guys... thanks for the info... I'm not flushing the whole system so moving away from the old grean isn't an option for me.
  #8
Old 03-13-2009, 02:27 PM
dixieland-diesels's Avatar
dixieland-diesels
Offline
owner/president
Member's Gallery
Send a message via MSN to dixieland-diesels
I dont think you need an additive if you use the original motocraft gold.Please correct me if im wrong,before i mess something up.
__________________
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
  #9
Old 03-13-2009, 02:56 PM
Powerstroke Racer's Avatar
Powerstroke Racer
Offline
7.3 PSD Mythology Expert
Member's Gallery
I have been told that Baldwin CS5008 will work in place of the Ford stuff at a fraction of the cost, but I'm just noticing that it says nothing on the bottle about specs.
on edit Baldwin BTA Plus is the DCA4 equivalent.
__________________
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination. Diesel Innovations Online Performance Diesel Products!
  #10
Old 03-13-2009, 03:09 PM
Rustler
Offline
"mad cow" member
Member's Gallery
The Motorcraft premium gold coolant supposedly does not need additional SCA.
AFAIK the only 7.3 SD’s that came from the factory with this coolant are 02-03.
I personally have little confidence in the gold coolant. I changed my 02-03’s within 50,000 miles to green with the proper concentration of DCA4.
Now as service life dictates they are being changed to a heavy duty ELC.
The gold and the green are not compatible and should not be mixed.
  #11
Old 03-13-2009, 03:28 PM
madpogue
Offline
Member's Gallery
Best price I've found for Fleetguard DCA4 and three-way test strips is Ryder Fleet products - http://www.ryderfleetproducts.com . I have no affiliation with them, just happened to find them significantly cheaper for these products. One caveat - the test strips usu. have a pretty short shelf life. I bought some last November, and they expire this month. Dunno if other sellers have them "fresher" than that, though.
  #12
Old 03-13-2009, 03:49 PM
Rustler
Offline
"mad cow" member
Member's Gallery
I prefer Fleetguard DCA4 which is a nitrite-molybdate-phosphate mix and a direct replacement for the Ford VC-8.
You can buy a gallon jug of the right stuff for around $34 or a pint for around $8, why cheap out on the protection of your cooling system.
I forget which brands are but some are a nitrite only formulation. I donít believe any damage will occur by the use of this type, Imo they are a less desirable product.
Don't make me go all Gooch on yo ass
  #13
Old 03-13-2009, 03:52 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Need to get me a gallon of that stuff.
  #14
Old 03-13-2009, 04:04 PM
444-4D's Avatar
444-4D
Offline
Caption This
Member's Gallery
You can use either DCA-2 or DCA-4. It comes in various brands. I always use Fleetguard branded stuff because it is easy for me to get. If you aren't flushing the system it would be best to use the same kind that is currently in there. If you have no way of knowing it isn't a big deal because you can mix DCA-2 & 4 without any issues. I'd use a Fleetguard strip that tests for both molybdate and nitrite (CC2602) even if you use DCA-2 because you might have some molybdate in there from a previous dose.
Ford Gold coolant has a minimum dose of DCA-2. You can enhance it's protection by adding either DCA-2 or DCA-4.
__________________
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
  #15
Old 03-13-2009, 04:08 PM
444-4D's Avatar
444-4D
Offline
Caption This
Member's Gallery
Only buy a gallon if you drive a lot of miles, it spoils. A half gallon is more than enough for a complete flush. Then you will need about a pint every 15,000 miles for maintenance.
  #16
Old 03-13-2009, 04:10 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
How long does it last in the bottle. I average about 30K a year. I am fixing to do a complete flush within the next couple of weeks.
  #17
Old 03-13-2009, 04:16 PM
444-4D's Avatar
444-4D
Offline
Caption This
Member's Gallery
I'm not sure how long it lasts. It should last a year or two if it was fresh when you bought it.
  #18
Old 03-13-2009, 04:53 PM
mattr66's Avatar
mattr66
Offline
Snake Oil Salesman
Member's Gallery
I'm pretty sure there was slim to none in there when I started from the previous owner's neglect I'm starting out on the right foot.....
  #19
Old 03-13-2009, 05:51 PM
dixieland-diesels
Offline
owner/president
Member's Gallery
AFAIK the only 7.3 SDís that came from the factory with this coolant are 02-03.
I personally have little confidence in the gold coolant. I changed my 02-03ís within 50,000 miles to green with the proper concentration of DCA4.
THANKS!
  #20
Old 03-13-2009, 05:54 PM
bbbxcursion
Offline
ARMY bound
Member's Gallery
I used to jerk off in the coolant, made it nice and slick.
  #21
Old 03-13-2009, 10:42 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Way too much info.
  #22
Old 03-13-2009, 10:48 PM
mattr66's Avatar
mattr66
Offline
Snake Oil Salesman
Member's Gallery
It's 40 degrees and raining outside so I'm not pulling mine out long enough to do that.....
  #23
Old 03-14-2009, 12:54 AM
Gooch's Avatar
Gooch
Offline
Member's Gallery
Like 444-4D said, either DCA-2 or DCA-4. Both great stuff. The NapaKool mentioned is DCA-2.
Ford didn't even come out with a SCA specification until late 2002. FW-15, FW-16, VC-8 , etc. were/are just Motorcraft part numbers, not specifications...just like a Motorcraft FL-1995 oil filter...it's a part number, not a spec. I think Ford knew by listing their own SCA spec in 2002 (ESN-M99B169-A), they could sell owners more of their own Motorcraft products.
DCA-2 and DCA-4 both do the same thing, using different methods. DCA-2 is Nitrite only and it's usually sodium buffered. DCA-4 is Nitrite/Molybdate with a potassium buffer. As mentioned, they are compatible and could be mixed if you had to. I like DCA-2 for reasons I won't get into here.
I've been told by SCA manufacturers that one of the reasons DCA-4 was developed was because it is less toxic to the environment. And one of the main reasons Ford began using it was because Fleetguard (who makes the DCA-4) is owned by Cummins, who at the time had interest and collaborations with Ford. And of course Ford and Navistar/International were also collaborating. So Cummins, Ford, and International all recommend using their own SCA, so-to-speak.
BTW, there are popular industry conversions available for using the easier-to-find 2-way test strips with DCA-4: Basically 800 ppm of Nitrite on the 2-way strip is equivalent to 1 DCA unit. 1200 ppm of Nitrite on the 2-way strip is equivalent to 1.5 DCA units. Or every 400 ppm of Nitrite is equivalent to .5 DCA units.
SCA is "old-school" compared to the modern HD ELC diesel coolants. But it is very proven.
Cheers. Gooch.
__________________
01 F350 PSD 4X Crew Auto SRW
WD chip, turbo filter, guages. Walker straight-thru, APCM, Astrostart, Custom 4X shifter, ProHeat oil heater, Rancho RS9000's, WeatherTech's, Husky liners, Aircraft lights, TorkLift tie-downs, Line-X, Custom hitch, toys to pull and haul.
09 Hyundai Sonota Lmtd
04 Ford F-150 4X4 SC
83 Toyota Supra
  #24
Old 03-14-2009, 01:00 AM
Powerstroke Racer
Offline
Member's Gallery
Cheers. Gooch.
Good info, could you elaborate on the ethylene glycol concentrates of the DCA-2 vs the DCA-4 meaning the DCA2 says you have to have at least 30%, DCA-4 0%, now what happens if you have less than 30 % with the DCA-2?
  #25
Old 03-14-2009, 01:03 AM
TheDurtyDeez
Offline
Member's Gallery
Has anyone used the EVANS NPG+, NPG and NPG-R Coolant that dieselsite sells on their site? Where does this compare to using regular coolant with the additive?
I am thinking about draining the coolant and switching to the evans stuff, but if it considered harmful or not worth the money, I will just go back to something mentioned above.
  #26
Old 03-14-2009, 02:40 AM
dixieland-diesels
Offline
owner/president
Member's Gallery
I've used EVANS before in my cummins and d-max,but not in my strokers, yet,from all the info i gather it seems to be the best-longest lasting coolant.just my $.02 (still gathering info)
  #27
Old 03-14-2009, 02:45 AM
444-4D's Avatar
444-4D
Offline
Caption This
Member's Gallery
Are you referring to coolant you would use for drag racing or is there some other reason you want less than 30% ?
  #28
Old 03-14-2009, 06:12 PM
f250 hd Powerstroke
Offline
Member's Gallery
I change my coolant every season with 50/50 peak and then add the fw-16 charge from ford. I was told from the diesel mechanics at ford you only need one bottle. But my question is would I half to test the coolant if i change it every season
  #29
Old 03-14-2009, 07:48 PM
444-4D's Avatar
444-4D
Offline
Caption This
Member's Gallery
How many miles do you drive per year and which Peak 50/50 do you use?
  #30
Old 03-15-2009, 04:51 PM
f250 hd Powerstroke
Offline
Member's Gallery
I drive it about 2000 a year at the most i just got the truck about a year ago the truck had been sitting for 7 years and i got it and have been keeping the coolant clean because it turns brown about in 500 miles there for i change it every season to keep it clean. But i use 50/50 long life.
  #31
Old 03-15-2009, 05:07 PM
444-4D's Avatar
444-4D
Offline
Caption This
Member's Gallery
If your coolant turns brown in 500 miles, your cooling system needs some attention starting with a good flush. I wouldn't use the coolant you are using. For Peak products, I would use either Fleet Charge or Final Charge or one of their conventional coolants such as Full Force. What year is your truck?
  #32
Old 03-15-2009, 05:19 PM
mattymx's Avatar
mattymx
Offline
<----Colin Banks
Member's Gallery
I always go to International and get their Fleetrite coolant that already is treated with the additive. For some reason this coolant seems to keep its additive longer than when I added it myself. Go figure.
__________________
><> MY TRUCKS<>< YouTube Vids
  #33
Old 03-15-2009, 05:49 PM
444-4D's Avatar
444-4D
Offline
Caption This
Member's Gallery
Going to IH and buying Fleetrite if fine but you can get fully formulated coolant many places. Peak Fleet charge was the first fully formulated coolant I can remember seeing.
  #34
Old 03-16-2009, 02:08 AM
f250 hd Powerstroke
Offline
Member's Gallery
the truck is a 1997. dont they sell finalcharge at walmart. would you just use 4 galons of final charge or do you just use one and then 50/50?
  #35
Old 03-16-2009, 02:17 AM
444-4D's Avatar
444-4D
Offline
Caption This
Member's Gallery
I wouldn't use Final Charge in a 97, but I would use Fleet Charge. You could use one gallon of concentrate and six gallons of 50/50 but it is probably cheaper to buy 4 gallons concentrate and 4 gallons of distilled water.
  #36
Old 03-16-2009, 02:35 AM
f250 hd Powerstroke
Offline
Member's Gallery
thank you
Human Verification
(View-All Members who have read this thread : 180
01strokin, 02BigD, 02F350, 1badz, 444-4D, 444smoker, 96 stroker, 99F250Smitty, 99redf350, Aaron S, abbottfarms, abianca99, adcausey, aggie, aklim, AMB, Archery Hunter, Arisley, BackRoad_Flyin', bassanglerbob, BDHABT, BDS, bhanger24, bigjake0524, bigrngyj, bigwhite7.3stroker, bismic1, bknight187, BlackPearl03, Blowby, BMac, BMF7.3, bobzilla1959, BoilermakerSteve, BoomerL37, bpa658, Bradbilt, BTDESTROYER350, Bushwakd, c.salt, Campspringsjohn, casper, CATdiezel, chappy, chopper, Choupique108, cimarron13, CPD4th, crowz, CumminsRanger, damdifino, dan_k, Darkhollow, dblamp, Deputydog, Derek2001, dezl, Diesel Avenger, DIESEL DAN, Dieselfever, DieselPower1966, dilligaf, DIRTBIKEZ, dirtbro, Divebomber, dixieland-diesels, doubledoor, Driles85, dspowerstroke, dubswyoming, dzlstroker, elk junkie, ELMSS12, F-350, f250 hd Powerstroke, fastbee, fixithud, FleetMan, FordCowboy, Front Runner, gahellinger, gary02psd, genuineford, godzillas dad, golfer, Goober1979, Gooch, GreenF350, Harohunter, hawkeye, Hippie, HMBUILDER4U2004, itsmyduty, jaybuller, jd2010, jeremiahmercier, Jngreen, John-Boy, johnday, jrogers17, JuststrokeIT, jwkirkpatrick, kantorn55, krankin, kystanger, Lee, lep, Leroy1, Loganj01, losfinch, LRTMatt, madpogue, MagKarl, Mark70, Marty, Matt-F350, mattr66, mattymx, mflores, michael521, MikefromMT, mimetic, mista miller, mowrus, mpvoss, MrOneEyedBoh, MudSouth, Nelly, npen, Ohnny101, philzman, Pipewhiner, pitbull62, Powerstroke Racer, psdmike, psduser1, R.J., RA3PSD, raptor, Redfish, RichWT, Rodknocker, rpenner54, Rustler, SD01WD, Shepherd Boy, SKWERL, smithm31, smokinndstrokin, sneaky09, solareclpse2000, stoneykegonsa, Stroke00, Stroked-n-AZ, sttstroke, SyN, Tampa450, tank, tbolt, tch.280, Tedzz, texans, TheDurtyDeez, theSLEEPER, thetonka, Tom S, tomspear, TrailerHauler, tubular031, turbtators, wayner, wooner, zgcain, zilla68
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
