Random miss - can't figure it out - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 03-01-2009, 04:59 AM
GTRjd
Offline
Member's Gallery
Early '99 Crew Cab 7.3PS 4X2 192K miles. All stock...
Originally started out what seemed to be a cold start issue....In the morning, it normally be a bit sluggish. 1 in 10 it would romp. Only died once in about 4 months since I had it. Sometimes it would be fine. As I got about 5 miles down the road...it would warm up and run fine.
Gene ran the codes for me along with a contribution and buzz test. No codes, buzz test was fine. Contribution showed low on 8 the first time....then low on 5 and 8 the second. Recommendation was a look at the IPR.
I pulled the IPR, looked fine....cleaned it anyway. Put it back, no change.
About a month ago, cold start, jumped on the highway for about 3 miles, went up an on-ramp and as the lockup disengaged the RPMs dropped right to zero. Waited 15 seconds, truck started up and no more problems.
Two days later I was driving up the highway and I head a distinct change in tone....it sounded like knock.
When I stopped, truck was missing badly...felt like a gasser with a HUGE Cam and a nasty lope. When I gave it throttle, it couldn't feel it.
I've replaced the oil, fuel filter (bowl was pretty nasty), GP relay, CPS (which resulted in a failure of the Tension assembly and Serpentine belt....now both new). GP's have all been ohmed and look good.....I haven't had it romp in quite some time....but it will idle crappy in warm or cold weather when I start it.
I've tried using an IR gun to see if one of the holes wasn't firing....but each runner seemed to be about the same temp (around 270deg).
Worst of all....problem is completely intermittent. I fired up the truck this afternoon after not running it for a couple weeks and it felt pretty smooth. No miss. No knock. WTF?
By the way....Why do Autozone and Kragen both tell me my serpentine should be a 1215 (121.5") instead of the 1223 (122.7") that actually fits? A little online research seems to indicate the 1215s were indeed for the 99 and 00 trucks....why does mine need a 1223?
Reply With Quote Quick reply to this message Go to the top
Old 03-01-2009, 05:01 AM
GTRjd
Offline
Member's Gallery
Re: Random miss - can't figure it out
By the way...don't know if its relevant....but ANYTIME the lockup disengages from highway speeds, the RPMs drop too low and the truck flutters between 500 and 750 RPM until it dampens out.
  #3
Old 03-01-2009, 05:05 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
You say you replaced the fuel filter. Try this. Drain the fuel bowl, remove the fuel filter cap. Fill the bowl with Seafoam. Replace cap. Put the couple ounces left of the Seafoam in the fuel tank. Start the motor and let it run for a while.
Why did changing the CPS take out the belt and tensioner? On my truck, I have a vacuum pump down on the bottom that was put on there aftermarket for a vacuum over hydraulic trailer brake setup. Do you have one of those on there?
__________________
  #4
Old 03-01-2009, 05:25 PM
GTRjd
Offline
Member's Gallery
Thanks, I'll give it a shot.
I removed the belt thinking it would be easier to get at the CPS (wasn't much).
When I went to replace the belt, the tensioner broke off axis as I was reinstalling it. I didn't notice it at the time, but the belt shredded a couple days later....
  #5
Old 03-01-2009, 07:44 PM
golfer's Avatar
golfer
Offline
fueled by Colecovision
Member's Gallery
the poppet valves within the injectors are toast.
typical symptoms are hard starting & runs rough cold, runs better hot...
take care~
Dave
__________________
swampsdiesel.com
toll free 866-595-8724
click to send email
  #6
Old 03-01-2009, 08:29 PM
Mr. Jimmy
Offline
Member's Gallery
Mine had a random miss at idle. Try unplugging the ICP sensor while the truck is running, that may cure your problem. Also check to see if you have oil underneath connector of sensor, this usually indicates a bad sensor.
__________________
2000 PSD Crew cab, Auto, 4WD, Elite Diesel chip
Quadzilla, dual 4" exhaust, WBTM, Tymar Filter
Wicked Wheel, 6.0 trans cooler.
  #7
Old 03-02-2009, 01:50 AM
GTRjd
Offline
Member's Gallery
Okay....did seafoam treatment- no change (fuel filter and bowl was clean as a whistle by the way so it looks like the fuel is okay)
Unplugged ICP - brief jump in RPM, resettled and have the exact same miss.
If I give it slight throttle, the miss will appear to go away at 1000RPM....the second I ease off the throttle in the slightest (say I drop to 900 RPM) it will miss and then run reasonably steady. As it idles around 600, it will miss about once/ 2 seconds. 750 is around once/ 3 or 4 seconds.
I'm currently uploading a video to photobucket so I can show the miss.....
I figure I'll take it to the stealership to have them check fuel pressure before I bit the bullet and get a set of injectors
  #8
Old 03-02-2009, 01:52 AM
mattymx's Avatar
mattymx
Offline
<----Colin Banks
Member's Gallery
Can you get a video with sound of your truck? That might be helpful.
__________________
><> MY TRUCKS<>< YouTube Vids
  #9
Old 03-02-2009, 02:48 AM
GTRjd
Offline
Member's Gallery
  #10
Old 03-02-2009, 04:07 AM
GTRjd
Offline
Member's Gallery
More info. I noticed today that it doesn't miss on start-up....unless the engine is still HOT. IE if I shut it down and leave it for an hour, it will start right up and run great for about 10 minutes....then it will start to miss again.
I drove it from my house about 30 miles to a park....ran great. Had a picnic with the fam for a couple hours and it started up great and ran smooth until I hit the offramp near the house. When I stopped at the light, it was missing again. The only difference between the trip out and trip back was that I limited my speed to 60 on the way there.....and went up to 70 on the way back. Don't know why that seems to matter....
  #11
Old 03-02-2009, 07:09 AM
Firedogbme's Avatar
Firedogbme
Offline
PSN's resident Blue Man
Member's Gallery
Look at the wiring going into the IPR, and at the connector itself. Some of these trucks have issues with fuel and oil damaging the insulation on the wiring. I've found it on my IPR connector and on a UVC harness connector.
__________________
Early '99, 4X4, CC, SB, Fire Engine Red
-JNB Fuel System, Sinister Overboost, C2 gauges, AFE Stage II w/ "JAT99" Intake Pipe, CCV Bypass, 3.5 dp to 4" exhaust.
-BTS Trans and Converter
-WOP QSSB Turbo
-Terminator HPOS
-DP F5 w/ 60Tow, 80Econ, 120Race, 140Extreme, High Idle, Upgraded to PMT PCM - Live tuned
  #12
Old 03-03-2009, 03:27 AM
GTRjd
Offline
Member's Gallery
Wiring looks good at least at the connectors until it goes into the plastic sheathing.
Here's a video from cold start-up to warm this morning. It was about 8:30AM
I started the truck again at around 3:00PM...cranked right up and ran great for about five minutes...then began missing. Ran that way for ten minutes....then stopped missing for a while...then did it again until I got home.
  #13
Old 03-03-2009, 03:32 AM
GTRjd
Offline
Member's Gallery
By the way.....no smoke. When it first started having this issue there was a bit of blue smoke....now nothin....unless of course I put the pedal to the floor....
  #14
Old 03-03-2009, 04:38 AM
golfer's Avatar
golfer
Offline
Member's Gallery
that video is one of a truck with a dead miss.
There are multiple diagnostic checks you can have performed by a competent tech at an independent shop or the dealer...but you definitely have at least one injector down.
take care~
Dave
  #15
Old 03-03-2009, 05:16 AM
GTRjd
Offline
Member's Gallery
Aye...thanks. I'll take it in tomorrow....
  #16
Old 03-03-2009, 05:20 AM
golfer's Avatar
golfer
Offline
Member's Gallery
give me a shout, and I'll tell you a couple of things to have the tech check out...
rather than him just punching buttons on the scantool waiting for it to spell everything out for him...
  #17
Old 03-03-2009, 05:40 AM
GTRjd
Offline
Member's Gallery
Sure thing!
Any probable reason why sometimes it starts like crap while other times starts just fine on cold start? Does a dead hole not cause an SES? I figured if it was worn injectors it would always behave in a similar manner from a cold start.....
And how bad have I screwed up my truck by driving it?
  #18
Old 03-03-2009, 03:38 PM
golfer's Avatar
golfer
Offline
Member's Gallery
Originally Posted by GTRjd View Post
Sure thing!
no, the only thing that will throw an SES light is a wiring (or electrical) problem with the PCM-IDM-Injector...
The PCM does not actively monitor injector (or cylinder) balance. It does however, actively monitor electrical continuity.
take care~
Dave
  #19
Old 03-03-2009, 10:14 PM
fixithud
Offline
Member's Gallery
Keep this alive please!!!!!!!!!!!!!!
Please!!!! Keep this thread moving along with ALL and ANY information that you come up with concerning this truck's issues. I have similiar issues on my 550 and I am down to getting ready to replace #8 injector.
I have good starts but crappy cold power, I think a miss also. I can't really tell. Buzz on 8 is sometimes weak, like a towel is over it. The truck will run very well, but not all the time. Replaced drivers side uvch have tried different icm with no change.
Hud
__________________
1995 F-350 srw, cc, auto, gutted ebpv, shot the cat, 3 pos. Tymar chip. 350,000 miles as of 2-11, will she hold together??
  #20
Old 03-03-2009, 10:30 PM
golfer's Avatar
golfer
Offline
Member's Gallery
it's the poppet valve in the injector, Hud...
  #21
Old 03-03-2009, 11:45 PM
fixithud
Offline
Member's Gallery
I wish you would quit reminding me how smart you are...
But remember.. I can plug in an injector without a net.
  #22
Old 03-03-2009, 11:49 PM
golfer's Avatar
golfer
Offline
Member's Gallery
ok, no problem
  #23
Old 03-04-2009, 12:40 AM
fixithud
Offline
Member's Gallery
I see your icon there Dave... Just hassling you a bit.
I know you remember me. The guy in Virginia with the 550 that had an injector not plugged up good.
I am still having an issue similiar to the one the starter of this post is dealing with. I think number 8 is my issue and I procured a good injector from a friend of mine. I am just hoping that replacing it will clear up my problem.
It bugs me to no end that I have one truck, 1995 with 300k miles, that runs so much better than a 99 with 220k AND has already had one set of injectors.
Just another day... If the trucks were not giving me problems it would just be somthing else I guess.
Seriously, I appreciate your knowledge and help.
Hud
  #24
Old 03-04-2009, 12:52 AM
golfer's Avatar
golfer
Offline
Member's Gallery
ok, cool...thought that was just a 'jab'
...but wasn't too sure how bad I rubbed ya when you...mmm..you know...
holler sometime~
Dave
  #25
Old 03-04-2009, 03:17 AM
Motownfire's Avatar
Motownfire
Offline
<----My last CT scan
Member's Gallery
What different things should be checked out ???
__________________
  #26
Old 03-04-2009, 06:58 AM
GTRjd
Offline
Member's Gallery
Spoke to Dave before I took it to the dealer.....awaiting confirmation on the issue. The real question is....do I do these things one at a time as they fail....or just go through in a single sweep and replace them all? How would I know if any have already been replaced? Is it possible to know?
If I pull them all out to inspect them, as with most other seals, would I need to replace the O-rings or can they be re-used?
  #27
Old 03-04-2009, 03:52 PM
mandkole's Avatar
mandkole
Offline
Member's Gallery
Unless you just replaced the orings real recently (in the last couple weeks), put a new set on. Lube with ample amounts of oil on reinstall.
On the inj that you're having trouble with, have you pulled the solenoid off and checked for a loose armature/poppet screw? If loose, it will shut down the injector down. Old injectors will get loose poppet screws and its a very easy thing to check and repair if loose.
__________________
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
  #28
Old 03-05-2009, 01:28 AM
GTRjd
Offline
Member's Gallery
Word is - P0275 #5 Cylinder Contribution fault.
That was the only code he pulled.
Wasn't able to speak directly with the service tech...so I don't know exactly what tests he ran. I know what I asked for, we'll see what he gave me.....
Dealer is also trying to say that blowby is excessive.....
According to my understanding of the the oil cap thumb rule....if you can place the cap upside down on the filler neck and it stays (aside from vibrating off) its fine... Anyone have anything to the contrary?
  #29
Old 03-05-2009, 03:36 AM
golfer's Avatar
golfer
Offline
Member's Gallery
I would suggest you pull off your air intake tube (from the airbox to the turbo inlet)...and peek into the compressor housing and inspect the wheel for signs of damage.
Also take a close look at the air filter 'box' where the filter goes...if the tabs are broken, missing, and/or the spring clasps broken or missing, then things aren't looking too promising...inspect the inside of the intake tube for grit, sand, dirt, etc...though oil in that tube is perfectly normal from the crankcase vent that redirects the oily mist from the valve cover into the intake tract.
On the turbo...the outermost perimeter of the fins should be very nice & crisp right angles...if the outer perimeter of the fins are rounded, bent, "thinned", or sandblasted looking...then you probably need to have a compression test performed...prior to dropping x hundred bucks on an injector & installation.
but yes, excessive crank case pressure would lift the lid off of the oil filler neck...
take care~
Dave
  #30
Old 03-05-2009, 06:39 AM
GTRjd
Offline
Member's Gallery
When I originally Ohmed my GPs when I had hard start, the intake piping was pretty clean, and the compressor looked good. The tabs for the filter and springs were all in place when I replaced my filter not too long ago.....but I'll take a good look at all of it again.
For what they want to pull the valve covers off and check underneath (some 370 bucks) I'll buy a diesel kit for 80 bucks and do the compression test myself. I'm thinking the dead miss in conjunction with no smoke lends credence to a bad injector/harness. I've read a number of posts outlining a pretty good bit of white smoke when blowing unburt fuel out the exhaust....
Was this brought on by the excessive blow by comments?
The contribution fault seems to lend credence to a bad injector....especially if I get a SAT buzz test, right?
  #31
Old 03-05-2009, 06:42 AM
GTRjd
Offline
Member's Gallery
Oh....and I'm still getting 18-20 mpg combined driving.
  #32
Old 03-05-2009, 07:23 PM
mandkole's Avatar
mandkole
Offline
Member's Gallery
Did the buzz test confirm #5 also? If you are pulling the valve covers, I'd check for a loose poppet screw. It will give a funky buzz result and kill the injectors operation (almost like its turned off).
On your earlier belt question, the Gates interchange info notes a 122.3" belt.
  #33
Old 03-05-2009, 07:25 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Can you replace poppet valves on the injectors if you find a bad one?
  #34
Old 03-05-2009, 08:22 PM
GTRjd
Offline
Member's Gallery
The tech said he believed the test was SAT. But yeah....dealer is telling me the engine is dusted and I need a LB. I don't believe it yet.
I've asked for the measurement of the "excessive crankcase pressure" and the operating temp at which it was done.
I would think with a dead miss, and a low comp cylinder, I would see either a pretty good amount of white smoke in the exhaust or a heavy puffing oil filler neck. Is it possible to have a dead cylinder due to compression not exhibit either of these symptoms?
I'm going to pick up the truck this afternoon and examine the comp wheel as Dave said and pull the valve covers and hit the injectors with a feeler guage (as I read in another post to identify poppet wear). I guess I can do a Valve cover off test to check injector operation.
By the way....I told the dealer I was picking the truck up (ie you are not servicing my truck) and fifteen minutes later they called to tell me a power steering line burst while the tech was backing it out of the garage....repair cost 145 bucks......
I'll be posting more pics this evening or tomorrow morning to continue ts'ing
  #35
Old 03-05-2009, 08:27 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Tell them you want to see the "burst" line. Pick one up at the parts store, and replace it in their parking lot.
  #36
Old 03-06-2009, 12:11 AM
GTRjd
Offline
Member's Gallery
Bad news....
Took the intake off and noticed a tab had broken off.
Looked at the compressor - toasted. You can see grit/residue on the walls leading in to the wheel....
In addition the puffing out the filler neck is worse than before... its heading downhill fast.
Do I even need to bother with a compression test? I'm assuming the engine will continue to eat itself and destroy the cylinder walls if I keep driving it right? On the bright side....at least I get a chance to rebuild a diesel.....
Thanks for the help so far Dave....
Major bummer.....
  #37
Old 03-06-2009, 02:45 AM
golfer's Avatar
golfer
Offline
Member's Gallery
ugh...
Sorry to hear, JD...
I swear to gawd...whichever Ford engineer designed the POS air boxes on the 1994-2003 trucks should be strung up by his 'nads.
I mean, at the end of the day...it's the owner/operators responsibility to maintain his/her vehicle...but 70% or more 7.3's we see have had near death experiences due to broken filter lids, cracked intake tubes, etc.
Dave
  #38
Old 03-06-2009, 03:12 AM
GTRjd
Offline
Member's Gallery
ugh...
Dave
Do you guys have rebuild kits? And what all would you recommend to replace during a rebuild (assuming damage is minimal)? Don't need 1000ft-lbs....stock is just fine....
  #39
Old 03-06-2009, 03:45 AM
golfer's Avatar
golfer
Offline
Member's Gallery
yeah...
shoot me an email
dave@swampsdiesel.com
and I'll reply with a full quote...
pistons & rings, bearings, full eng gasket kit, new valves, etc..
of course you'll need to have the block machined (overbored, honed & decked)...and if you want to mess with the heads (deck, new valves) I would suggest thin bronze valve sleeves (prevents valve stem & seat wear).
take care~
Dave
  #40
Old 03-06-2009, 07:13 AM
GTRjd
Offline
Member's Gallery
What do you think of this air filter kit?
Motorcraft FA-1759 Ford 7.3 Power Stroke AIS Severe Duty Air Filter Kit
I may have to drive the truck a little before I can do any work....I'll clean all the piping, replace the filter assembly and do an oil change to help minimize further wear....
  #41
Old 03-06-2009, 05:04 PM
golfer's Avatar
golfer
Offline
Member's Gallery
I would just get the WIX 46637 filter from NAPA, pull all of your factory airbox crap out of there, and lay the filter in behind the drivers side battery.
  #42
Old 03-13-2009, 06:01 PM
GTRjd
Offline
Member's Gallery
Alright...have some time this weekend....
Ordered a couple injector rings and a new Comp wheel from Swamps..hope they show up today or tomorrow.
Grabbed a WIX filter....should be here today.
I picked up/assembled a "Harbor-Depot" Compression tester for $35 and will give it a run this afternoon or tomorrow morning. Hoping for the best....
Also planning on swapping the injector in #5 with whichever cylinder is giving me my best compression hoping its a combination of injector issues and compression loss on that cylinder. Maybe I can at least reduce the miss a bit to make it a bit more driveable until I have time to tear it down....
I'll post results when I get 'em.
  #43
Old 03-14-2009, 04:45 PM
GTRjd
Offline
Member's Gallery
Having trouble with the compression test.....
I can't thread the nipple into the glow plug holes as the rocker arms seem to be in the way.....the angle isn't right and I certainly don't want to cross thread the thing....
Am I supposed to have to take the rocker arms off to do this?
  #44
Old 03-14-2009, 04:58 PM
mandkole's Avatar
mandkole
Offline
Member's Gallery
Most compression test kits don't have the PSD adapter, only the IDI. I've never heard of a $35 kit for a psd. I'm assuming you have the correct (long) glowplug adapter. If it is correct, the fit is tight; I recall having to use the remote starter to rock the motor a little on some insertions to make sure the position was correct on the rocker arm for clearance.
  #45
Old 03-14-2009, 05:10 PM
GTRjd
Offline
Member's Gallery
I'm using a 4X1/8" nipple connected to a 1/8" female to female union that connects to the compression tester.
In the correct adapter is the body of the adapter thinner than the threads, or is it the same diameter?
  #46
Old 03-14-2009, 06:39 PM
GTRjd
Offline
Member's Gallery
Ahhhh....think the thread side is wrong....I'll figure it out....
  #47
Old 04-11-2009, 07:37 PM
GTRjd
Offline
Member's Gallery
The good news...finally manage to piece together a working compression tester ($67 total)....$30 Harbor Freight Diesel Comp Kit, $32 adapter (TU-15-22A) and a 3 dollar fitting from a local pipe and fittings shop.
The bad news....looks to be dusted.
Compression results on a 5 crank test - all gp's out
7 - 300 8 - 340
5 - 200 6 - 320
3 - 325 4 - 360
1 - 360 2 - 360
So I've got 4 "decent" cylinders.
Funny thing...since I've put in the KWIX and changed the oil to RotellaT it doesn't miss anymore when its warmed up.....and the last few days it started without a dead hole....can't quite figure that part out.
I am going to pull the injectors on 5 and 7 and replace the 0-rings, as well as pull the pushrods and make sure they aren't bent.....but I think at this point, I'm grasping for straws....
  #48
Old 04-12-2009, 05:54 AM
GTRjd
Offline
Member's Gallery
Two quick questions....
How much does the block w/ accessories weight? IE...how big of an engine stand/hoist do I need?
Hazard a guess on an engine pull and replace time for someone who hasn't done it before?
  #49
Old 04-13-2009, 12:30 AM
golfer's Avatar
golfer
Offline
Member's Gallery
AC/DELCO - ENGINE STAND (1TON HD ENGINE STAND)
the engine, with accessories, will weigh in the 1000-1200lb range.
estimated first time to pull engine: 6 hours.
  #50
Old 04-20-2009, 06:12 AM
ADJDWG
Offline
ADJDWG
Member's Gallery
any news??
__________________
1999 F250 Crew Cab 4x4
2002 Lexus GS430
1990 300ZX Twin Turbo
1987 Mitsubishi Conquest Turbo
  #51
Old 06-05-2009, 05:38 AM
ADJDWG
Offline
ADJDWG
Member's Gallery
bump
  #52
Old 06-05-2009, 04:51 PM
TrailerHauler's Avatar
TrailerHauler
Offline
Custom Trailer Sales
Member's Gallery
I kind knew, but confirmed my problem on the phone with swamps yesterday.
On any cold start no matter the temperature, until the oil warms up near or to operating temp I will get a lot of blue smoke out of the tail pipe and a slight miss.
Also in the winter the truck would NOT start unless it was plugged in for a couple of hours, then when it did decide to start it would have a slight-bad miss.
I figured I needed injectors, and Swamps said it sounds exactly like a common worn out Poppet valve on an injector, so its time to round up coin for baby swamps injectors and some of their tuning!
__________________
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
Human Verification
(View-All Members who have read this thread : 248
01rod73, 20007.3stroker, 2001-7.3Liter, 84crewcab, 87notch, 96F350Kid, 96Powerstrokin, 97/03 psd, 99.5crewstroke, 99350sd, 99powerstroke350, A310, Aaron S, abbottfarms, ADJDWG, aejacques, aggie, AlaskanTrucker379, amthatiam, Ant Dog, Arisley, ascrap2003, BADASSPOWERSTROKE, Bar-m.cattle, Barnbuilder, bazdog1, BBottoms, BDS, bfife, bigd4me2, BIGLARRYS03, BigRed97, Bigrig62, biostroke1, Blackmax, BlackPearl03, Blowby, bludog, boggerr, Boomer, BoomerL37, boondocker13, BowHuntinFever, bryan.d, bsdracing, Bushwakd, buzz380, cadd, casper7.3, cemeyer, CGMKCM, chance b, chappy, CNDiesel, cowboycadillac, cowboy_dan, cravin, crowz, cutlass, Dane18, Dantheman, DcMoore999, Deputydog, dexleo2, DHTD, DieselBrad, Dieseldave73, dieselEJ, Dieselfever, DieselPower1966, dieselsmoke, Dieselsvt, DIRTBIKEZ, Divebomber, donj1977, Doodah, doubledoor, dzlstroker, e444, earlybroncoboy, EJ25GC8, ELKHUNTER, ELMSS12, f250power, f350red, F350_7.3, Fast coupe, fast1000busa, fbilly420, FDNYret, Fingernip, Firedogbme, fishinfool98, fixithud, flip2spin23, florida 6.0, FordCowboy, fordman4wheeling, fyrehose, Glock 20, Gobstopper909, golfer, Got Diesel, GTRjd, guzzle, Harohunter, haulin99sdp, have12, Hawker, hawkeye, HaysKSFirefighter, heavyhauler, hendershot, highfive, holleywood, hookin78, hoptwoit, hotshoe91m, ibleeddiesel, ironworker25, jaybuller, Jeep1947, JerseyJim, Jesse Lambert, Jet Fuel, joedaddy, Joedog, Joey7319, jrinalb, Justincredible, JuststrokeIT, kbmkviii, keep'erpinned, KingCrabb, krankin, LaFrance454, Lee, Lmgrcivic, LongGun_LeRoy, Madvan, MagKarl, mandkole, matthewd11, mattr66, mattymx, merlinnilrem, michael521, mob1, mojoman, moresrvc, mostrokin, Motownfire, mowrus, Mr. Jimmy, nasty96, nater77, neverkickn, newmexicocrawler, norcalsig, Nutz, ohiopsdfordman, Ohnny101, Old stroker, old96stroker, OldschoolPSD, outridin, ParkerFly, PeterB, phillipraysmith, PHPDiesel, PIGFUZ, Pipewhiner, portlandareae28, procomp, psd kid, PSDfan99, PsdPullerJR, qcfarmer, Ramblin'_Man, rconcrete, retired jeeper, rich in co, richyrich, rick ball, Riley250, Ripsaw, RLSCOAL, Rmartin-97, Rob02F350, Rogue1970, Rustler, ryanlathey, secondarychaos, sgleshot, sick97psd1, silverslug, sled hauler, Slogging, SmokeWithEveryStroke, smokyred, solostyle, SootRoller, SS317, stlhdfishr, straitcountry, stroked, stroker350, Stroker67, StrokerTurbo7.3, strokinak, strokinsince'95, suprdzlduty, SWVa, Tampa450, tank, TexasStroke01, TheDirt, theham1105, TheHumboldWagon, theSLEEPER, tholt34, Thuglike, toddg, tottav, TrailerHauler, TRX370r, ttles714, turboluke, umpalumpa1985, urbanwheeler, voodoomaker, Vug, wampaku, Weezer, Wheels, whitjo, wooner, yamt03, yobuda, yzdude250f, zharvey89, zs6.0
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
