ZOODAD is done when you remove the grill and drill a large hole or series of holes in the header panel on the driver's side.
If you remove the grill you will see the outside temp probe on your right side. If this probe isn't present you will see a large area that sits at an angle. Remove the sensor (if present) so it doesn't get damaged. Then find a hole bit and drill to your heart's content. If you have a dremel you can smooth the hole and increase the size if needed. Then get the hose so you can rinse the dust off and let dry, come back with some black paint to cover the edges for a stock look. I'd post pics but IT has us on lockdown.
