I need help my truck wont start.I turn the key all the lights come on the batterys were replaced last winter.i check them they have 13.5 volts with the off.turn the key and nothing not even a click.Could this be aCPS problem.Thanks for the help.I need to get truck started soon need to get my child from scholl
what year truck? programmer? i haad the same problem with my 6.0 and it was two wires melted together about 3 feet back from the transmission,but it never popped a fuse
Check all grounds. If they are Ok. Start chasing power. Follow the hot wire down to the starter, also follow the pigtail on the hot wire to the relay on the fenderwall. Make sure you are getting power through there.
Not real sure where it's located, but it sounds as though it may need to be replaced.
Just need to make sure your starter does not have a dead spot in it. I had the same issue in a Mustang, replaced the neutral safety switch and it did not fix it. If it does it again AND trying to start in neutral does not work. Tap the starter with a hammer it may take a couple of tries. If it starts then you probably just have a dead spot in the starter.
Is your shifter sloppy. There is a linkage under the column that comes loose. Held on with two torx screws. Just pull the piece off the bottom of the column and follow the shifter back. You will see it.
Thanks for the help I'll Check that But I don't think its sloppy.
