I'm doing alot of work with my Church, and the oil smell (Rotella Syn 5w40) is getting a little old. Does anyone have the draft fitting that goes into the intake tube before the turbo? I lost mine and need it to reconnect the CCV. I'm sure there has to be someone out there that did the CCV Mod that doesn't need theirs:shrug:
Well my idea is to pack a small can with steel wool, and route the CCV tube through it. I'll install a drain on the bottom of the can to drain oil from. The oil vapor should stick to the steel wool on it's way through and eventually fall to the bottom of the can.
I would rather just plumb it back to the intake without having to spend a ton on a filter.
Dump some cologne in your fuel. It shouldn't hurt it, and leave your exhaust smelling like cologne. Useless, but fun.
