my 05 6L started to blow white smoke at idle when warm and at take offs it is putting out a p0611 (fuel injector control module- performance)code and a p1378(not sure about this one) need some help please
thanks but i reset the codes and they have not come back. i cant get it to smoke at idle anymore and it only somkes white when i take off and it has been raining a lot here. i have been hitting a lot of big puddles could that be the problem the white smoke gets less and less
If you got the code from the SCT then I would have them checked again. I didn't see that you specified what you used to check it, but thats what I use for my truck and it was throwing P0611 FICM and I brought it to a shop and their device didn't find a code. But then again I haven't seen White Smoke since I bought my truck. If you didn't use SCT then disreguard this message. Just trying to save some stress if I can!
if it is under warranty have fun i took mine in and the fcim control modules are on back order nation wide till April. but the will put you to the top of the receiving list when the start to come in.
i just took it to the dealer cause it is under warrenty still so they said they might have one it should be here in two days
