fuel bowl heater plug - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto Escrow
Thread Tools Display Modes
  #1
Old 02-08-2009, 10:40 PM
96 stroker's Avatar
96 stroker
Offline
Old But Sexy
Member's Gallery
ok i need to un plug this but cant happen to find it.. i un pluged something on the pass side and it didnt start...pluged it back in and it started pretty rough but ran decent.. where is this pulg?
PICS WOULD BE GREAT!!
thank you
__________________
96 F-350 CCLB ,auto with a couple 6 inch black aussie stacks, A Dp-tuner and AD injectors 66mm turbo and BD t.c...
Dads-01 7.3 4x4 Excursion..stock as could be
Reply With Quote Quick reply to this message Go to the top
Old 02-09-2009, 05:36 AM
smokyred's Avatar
smokyred
Offline
What else?
Member's Gallery
Re: fuel bowl heater plug
The fuel bowl heater plug is a single wire square plug on the driver's side of the bowl, about halfway down. Make sure to tape it up so it does't short out.
Dave
__________________
My Pictures
  #3
Old 02-09-2009, 11:22 AM
96 stroker's Avatar
96 stroker
Offline
Old But Sexy
Member's Gallery
color or what it looks like?
  #4
Old 02-09-2009, 04:25 PM
MagKarl
Offline
Member's Gallery
You can also remove the heater from inside the canister and leave the harness plugged in on the outside.
__________________
1995 F350 4x4 CC 5 speed
RDS 160cc injectors
Tymar intake/exhaust
6.0L intercooler
TW chip
SD captains chairs
  #5
Old 02-10-2009, 02:41 AM
STROKER #1
Offline
Member's Gallery
In this pic you can see tree connectors, the middle one is the fuel heater.
http://good-times.webshots.com/photo...54971087iLHMoD
__________________
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
  #6
Old 02-10-2009, 02:45 AM
96 stroker's Avatar
96 stroker
Offline
Old But Sexy
Member's Gallery
thanks what is the top one?
  #7
Old 02-10-2009, 02:47 AM
STROKER #1
Offline
Member's Gallery
Fuel restrictor sensor and the bottom one is the water in fuel.
  #8
Old 02-10-2009, 02:50 AM
96 stroker's Avatar
96 stroker
Offline
Old But Sexy
Member's Gallery
would the top one have anything to do with the #22 maxi fuse.. cause it was bare wire on metal. I taped it up and it seemed to run fine.. i couldnt get that 2nd wire down off. but it was 50 degrees here so dont know if the bowl kicked on or not
  #9
Old 02-10-2009, 03:35 AM
STROKER #1
Offline
Member's Gallery
No the top on isnt related to the "22 maxi fuse, is the middle one. I is a spade connector with a boot, you can use a flat screw driver to unhook it.
  #10
Old 02-10-2009, 11:16 AM
96 stroker's Avatar
96 stroker
Offline
Old But Sexy
Member's Gallery
does it pull straight out toward like the fender or slide back cause we were tryin it and it wasnt movin even with a screwdriver..than it would move a little but the plastic base or the bowl was moving too
Human Verification
(View-All Members who have read this thread : 85
02BigD, 1996 stroke n, 1999SuperDutyStroke, 250turbo, 4doorshortbox, 700,000 powerstroke, 957.3powerstroke, 95powersmoker, 96 stroker, 96stroker, Alexhandro26, Arisley, ashman148, ashyez, Barnbuilder, blk7.3ks, bmorervns20, bobf3501995, Bushwakd, Centxdiesel, clem, cowboy_dan, crowz, D.T.Starr, daturbosix, Dieselfever, doubleshot, dukedrummer89, f250 hd Powerstroke, fast92gsx, goodstktbo, Grama, GreenF350, gutterguy, halerazor, hambony1, Harl, hawkeye, Holleran, hunter scar, jdffafarmer, Jeep1947, KansasStroker, kvn555, LaFrance454, mabe002, MagKarl, MikeHawk509, nashvillebill, oght6, ono_55, ParkerFly, PDR60, quaid27, Raddadninja, rcktman, ready81, reptillikus, Riley250, Robert_H, rpm-inc, rskeeters, RSP, Russ, Ryan V, sgh, sixiron, smokyred, spectreblazer, squeeks, sshelly, Stewie_95, stray cat, STROKER #1, tardymike, THE ALASKAN, tmillburg, trenner101, vapstroke, WayneT, wds1279, yzdude250f, zilla68
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
