I have a 2008 f250 crew cab short bed and I'm looking at the 10" fabtech lift but I really like the toyo open country mt's so I would need to go 15.50 wide and not the 13.50 that fabtech recomends. Does anybody know what I would need to do to make the 15.50's fit? My rims are driv blitz 20x10 I'm not 100% sure on the back spacing but I think it's around 4.5".
with 10" of lift you'll be fine but if you do anysort of tight turns especially with a 15.50 on a 20x10 you're going to run a bit...my recommendation is if you're wanting to run the 40's, bump up the lift 2" and run a 12" lift....you'll be much happier anyway.
here sis mine 10 inch fabtech with 4.0 coilovers 40 15.5 toyos fuel octane 20x12 -44 offset i just barely touch if im at full turn and hit a decent size bump otherwise no issues
Slowwheelie....yes you can run a 2"spacer on top. It won't harm anything at all...a good recommendation would be to go to a wider wheel as well....I have run 20x9, 20x10, 22x12, 22x14and now 24x12.....your best bet is a 12 wide
Thanks! I'm eventually going to get a 12" wide but for now I'm gonna try and make the 10" work.
