hey how many of the 6.0 guys have problems with the hpos? mine starts good cold,and runs good, once warm the commanded psi on a wot is 3900 psi and the commanded is 2300psi@85% duty cycl on the ipr. i ran a oil aeration test and the psi spiked to almost 4000 then fell to 1000. this was at 2 mins in the test. im checking the low psi pump tommarow. theres a new icp and connector and pump. the ipr is original. tested the branch tube with shop air,that feeds the injectors dint hear a leak and didnt lose oil. if the truck sits after a run/and soaks it either wont start or slow to build icp the ipr at this time is 85% let it sit about 1 hour and it will start and run/ will start quick too. what does anyone think? im thinking theres a problem with the low pressure feed.. let me hear everyones opinions thanks kyle...
