Lower Boost Numbers - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 07-13-2013, 10:51 PM
From384's Avatar
From384
Offline
Member's Gallery
Exclamation Lower Boost Numbers
Alright guys, Im new to the forum and couldn't find anything searching that helped me out. I have a 06 f250 that I just recently got studded with OEM gaskets, EGR delete, blue spring mod, and STC upgrade. Before I had the work done I was making around 25-26 lbs of boost all the time. Since getting it back Im only making 21 lbs. If I slowly accelerate I can get it up to 25-26 but only if a gradually accelerate. Will my check engine light being on from egr not being there cause it to make lower boost. Any help is appreciated.
Reply With Quote Quick reply to this message Go to the top
Old 07-14-2013, 02:53 AM
miller45103
Offline
Banned
Member's Gallery
Re: Lower Boost Numbers
If your CEL light is on it could cause issues. What codes do you have? Also, do you still have your old EGR valve? If so you should plug it back in.
Sent from my DROID RAZR
  #3
Old 07-14-2013, 03:56 AM
WarChild's Avatar
WarChild
Offline
Member's Gallery
We need the code. Could be a band clamp or a hose. Those are common issues after that work. Make sure they are out on correctly and are tight enough.
__________________
White 04 F350 Lariat SRW/CC/LB/FX4 207,XXX+
ARP Studs/BPD58V FICM Atlas40/BPD oil cooler/Powermax/155/30% Warren injectors
Edge insight CTS EGT/Turbo timer/SCT with Looney Wild Turbo
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
  #4
Old 07-14-2013, 02:15 PM
From384's Avatar
From384
Offline
Member's Gallery
the only codes that have are from the egr delete. low circuit and no flow. if I plug in the valve I still get the code for no flow.
  #5
Old 07-14-2013, 02:54 PM
toolmangary's Avatar
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
Are you sure about the before boost? usually they make under 20 stock.
I'd check your up pipes at the turbo for a exhaust leak, maybe that is causing a boost problem, I've seen it before.
__________________
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
  #6
Old 07-14-2013, 05:00 PM
From384's Avatar
From384
Offline
Member's Gallery
yea, like I was saying I can still make the 25-26 lbs but only if I slowly accelerate to WOT. if I quickly accelerate to WOT I only run 20-21 lbs.
  #7
Old 07-14-2013, 05:17 PM
wise guy
Offline
Member's Gallery
Check for leaks. If ok your going to need sct tuner newer pcm strategy will limit boost if egr does not function correctly. I leave the valve mounted in the intake and plugged in. older pcm strategy was ok with that but newer calibrations have to have egr tuned off with tuner. Or it will cause drivability problems
  #8
Old 07-15-2013, 03:27 AM
lenzhotrod
Offline
Member's Gallery
I have no proof, but my theory on EGR deletes is this. There is drive pressure turning the turbo. The drive pressure is usually higher than boost pressure. The EGR lets in this higher pressure, giving higher boost numbers. Delete the EGR your numbers are only reading true "boost pressure".
Registration Verification
Enter the first character in the word "Powerstroke".
Insurance
Please select your insurance company (Optional)
Human Verification
(View-All Members who have read this thread : 31
04 f350, 06leaker, acplowboy84, bassrippin365, BBowden73, Blue Hawg, bluesbish, Bob 86, dsberman94, Edogsf350, From384, Green 7.3, HeavyAssault, huck2080, IIvonnyII, isimar, James W, jtgf250, keblmo, mastrkee, Msolem, nitrouskid2601, polish pete, stroken1979, SureShot88, toolmangary, toycrawler, TVMC, Tweaker727, wise guy
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
