I currently have a 2001 F250.Im wanting to replace the 4/1 rear leaf springs with a set of 02 F250 6/1 rear leaf springs.Are all the Superduty rear leaf springs the same length and will interchange?01 is a SCSB and 02 is a RCLB,does it matter?And how much higher will my truck set in the back with the 6/1 springs?
im looking for advice as well i have a 6 inch and want to add 1-2 more inches my question is i was told by a shop i could use shackles ..but if i do willi need shims to correct angles to? seems like it would drop my pinion to far down..i dont want to take leaf springs apart for adda leafs im thinking 2 inch shackles in front and rear i just need it to clear bigger size i have 37s and thier close to rubbing i want to go 38
