made my 2000 a set of lift shackles that will give me about 1.5-2" lift in the front. My question is will I need a track bar and if so has any one customized the stock one. If so how did you guys do it
it won't kill you to get the lift in and then measure to make sure there is an axle offset
cut the trac bar, sleeve it, then center the axle( push the body and stabilize if it doesn't just find it's own center )) and mark the ends of the sleeve and weld it up
even if you need to drive it with the axle shifted a little won't be a problem
