P0264 code... Cylinder 2 injector circuit low - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto Escrow
Thread Tools Display Modes
  #1
Old 01-06-2009, 11:17 PM
Ramblin'_Man's Avatar
Ramblin'_Man
Offline
Hoosier daddy!
Member's Gallery
I just replaced the UVCH's and I'm still getting the P0264 code when I do a buzz test or a KOEO test. What could be the possible causes? A bad solenoid? Bad #2 injector? The engine runs fine right now, no missing that I can notice.
__________________
2001 PSD F250
Born 4/01 in KY USA,
4x4, 3.73, Ext. Cab, Shortbox...
ITP RR, CCV, Tymar Intake, Airdog, DP tuner
Reply With Quote Quick reply to this message Go to the top
Old 01-07-2009, 12:20 AM
diesel71's Avatar
diesel71
Offline
diesel tech
Member's Gallery
Re: P0264 code... Cylinder 2 injector circuit low
you could have high resistance in the injector solenoid. did you do a cylinder contribution test? a bad wire in the engine wire harness can cause that too,pin out the harness to eliminate that.
  #3
Old 01-07-2009, 01:51 AM
Ramblin'_Man
Offline
Hoosier daddy!
Member's Gallery
I ran the contribution test with AE and it performed successfully.
  #4
Old 01-07-2009, 04:19 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Mike, I know it is kind of time consuming, but try swapping the injector into another hole, see if the problem follows the injector.
__________________
  #5
Old 01-07-2009, 05:07 AM
smokyred's Avatar
smokyred
Offline
What else?
Member's Gallery
Check the resistance of that solenoid, and if it's the same as the others, swap it with another to see if the code follows.
If not, start pinning out the harness.
Dave
__________________
My Pictures
  #6
Old 01-07-2009, 10:53 PM
Ramblin'_Man
Offline
Hoosier daddy!
Member's Gallery
Ok guys... Thanks for the ideas. Since this isn't causing me problems right now, I think I'll wait for spring(warmer weather ) and then try swapping injectors/solenoids and see how things go from there.
Dave, can the solenoids be swapped without pulling the injector? Or will I have to go the route Andy mentioned, pulling the whole injector?
  #7
Old 01-07-2009, 11:37 PM
golfer's Avatar
golfer
Offline
fueled by Colecovision
Member's Gallery
you can swap a solenoid without removing the injector.
chances are it is not a bad solenoid, though.
We have an inductance meter, with which we use to check the solenoids... and we have maybe seen 4-5 bad solenoids in the past 5-6 years...tens of thousands of injectors worth.
It is possibly a bad solenoid, and maybe worth swapping on another solenoid for comparison, but we have seen high internal resistance, on the MOSFET drivers within an IDM create similar "bad solenoid" scenarios...so maybe try another IDM if the solenoid swap doesn't fix things.
...or it could be that the armature to solenoid clearances are not 'correct' on that particular injector creating a higher current flow through the IDM...
HEUI's are such lovely little things...
take care~
Dave
__________________
swampsdiesel.com
toll free 866-595-8724
click to send email
  #8
Old 01-08-2009, 01:03 AM
Ramblin'_Man
Offline
Hoosier daddy!
Member's Gallery
I had heard that the chance of an injector solenoid going bad was fairly slim. If I can swap one without pulling the injector, I will try that first. Actually, I think I'll just ohm all the solenoids first and see how they compare. What is the desired ohmic value of the injector solenoids?
  #9
Old 01-08-2009, 01:11 AM
smokyred's Avatar
smokyred
Offline
What else?
Member's Gallery
I can't recall correctly what the ohm value is of a good solenoid, sorry.
But the single bad solenoid that I've found was all black and melted underneath when I took it off, externally it looked fine.
Dave
  #10
Old 01-08-2009, 01:15 AM
mandkole's Avatar
mandkole
Offline
Member's Gallery
I think all of my old AAs were about 3.2-3.3 ohms...
__________________
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
Human Verification
(View-All Members who have read this thread : 83
03f250stroke, 03gregg, 1fstdsl, 305F250, 351c, 7.3EX, 95dump, 99F250Smitty, aklefty, Arisley, Barnbuilder, BDS, bigrngyj, blacksport03, Blowby, BoomerL37, Bushwakd, Chad Edwards, Chuggins10, Coltaine, CombatSent, dblamp, Deputydog, diesel71, dieselEJ, DIRTBIKEZ, georgia diesel, golfer, gotta_gofast, greenbeast, have12, injected79, isak, Jack Petrie, JDOliver, Jeep1947, JimTJr, Johnboy3, John_DeereGreen, J_F250, kyle43335, Layson, leoneo01, lght1, Longdrive, mandkole, Marty, matthewd11, mental floss, Mr. Elite, nasty96, nasty97, niklid05, notch86, nujef12, OBSWIZ, PHPDiesel, pipedobber, Pocket, PowerstrokN805, PSDfan99, Ptech, Ramblin'_Man, Riley250, Ripsaw, SD08, secondarychaos, SickFord, silverslug, skinny, skippy969, smokyred, star73, Stoker0560, Stroke00, strokerlahov, strokethis06, Super_Hauler, tch.280, The Oiler, Tinscout, UNLIMITED_DIESEL, wicked_four_play
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
