I want my truck to set level but I don't want to raise the front I want to drop the rear. Has anyone done this and if so pics. I don't haul much with my truck and mostly a boat the dose not squat it at all. Need help
My f350 dually has no blocks. Im assuming they were pulled by the previous owner at some point, everything I read say 2" is stock in that truck. It looks like it sits real close to level, but a tap reveals 2" difference in fender arches front to back. Its a crew cab, so I think the angle is just so slight over the wheelbase it looks level. Put 10k behind it and its just a touch nose high.
See..I think you are misunderstanding. .. when I first got my truck everyone said the same thing. .."get a leveling kit"... they couldn't understand that some of our trucks sit high in the front. .. adding a leveling kit would make it worse.
I didn't misunderstand ? you suggested a 1 inch block to replace the oem block to drop his rear
and I suggested on that bolts on vs just sits there
or a front coils spacer but He didn't want to raise the front
