7.3 liter powerstroke wont start? Changed Cam sensor/ checked filter still wont start - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 01-03-2009, 08:30 PM
zach91169
Offline
Member's Gallery
Angry 7.3 liter powerstroke wont start? Changed Cam sensor/ checked filter still wont start
So i had a problem the other day with my truck latley it has been running like crap and i accidentally ran it out of fuel for the first time ever.. I have a 1999 f250 superduty, with 111,000 miles on it and ever since i ran it out of fuel its been nothing but problems. Extremley rough idle, loud, big power loss, sounds like complete crap, shakes, dies on me, and you can put the pedal to the floor and takes a good 5 or 6 seconds before it feels like its getting sufficent fuel delivered to the injectors... So I changed the fuel filter, I noticed some buildup in the fuel bowl and i clean all of it out, but still runs bad... BUT NOW it wont even start at all, it died on me the other day out of no where, it turns over but wont fire, and ive done everything, i have checked fuses, I replaced the cam posistion sensor, made sure the fuel pump works, made sure there is fuel in the fuel bowl, everything seems fine BUT WONT FIRE... PLEASE HELP ME i am about to pull my hair out i have never had a problem with this truck till now and Its a nightmare!
zach
Reply With Quote Quick reply to this message Go to the top
Old 01-03-2009, 08:37 PM
Dave's Avatar
Dave
Offline
FNG
Member's Gallery
Re: 7.3 liter powerstroke wont start? Changed Cam sensor/ checked filter still wont s
Need to check fuel pressure. The pump may work but it may not be supplying enough pressure
__________________
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
  #3
Old 01-03-2009, 08:39 PM
zach91169
Offline
Member's Gallery
theres fuel in the fuel bowl so i know the pumps working? but somethings not letting it fire, i can turn the key over and it will feed fuel to the filter turns over wont fire...
  #4
Old 01-03-2009, 09:32 PM
DIRTBIKEZ
Offline
Member's Gallery
Are you seeing smoke out the tailpipe when cranking?
__________________
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
  #5
Old 01-03-2009, 09:41 PM
zach91169
Offline
Member's Gallery
no smoke at all
  #6
Old 01-03-2009, 09:42 PM
PSDfan99's Avatar
PSDfan99
Offline
Member's Gallery
__________________
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
  #7
Old 01-03-2009, 09:55 PM
zach91169
Offline
Member's Gallery
ALSO NO RPMS AT ALL WHEN I TURN HER OVER... EVEN AFTER CHANGING THE CAM POSISTION SENSOR!
  #8
Old 01-03-2009, 09:57 PM
Bushwakd's Avatar
Bushwakd
Offline
Edward Scissorhand WanaB
Member's Gallery
Check your fuses inside the truck. Fuel Bowl Heater is suspect. I could be wrong but give it a check.
I just went through that same crap last week on two of my work trucks. It ended up being a 30 amp fuse inside the truck at the fuse panel. My guess is your fuel bowl heater is kicking the fuse. The fuse controls the PCM Relay, Fuel Bowl Heater, IDM Relay. I bet you have no Wait to Start Light either on the dash. If you try and scan it you might not have any communication with the PCM at all.
__________________
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
  #9
Old 01-03-2009, 09:59 PM
zach91169
Offline
Member's Gallery
HEy you are right there is no wait to start light on the dash either! i check the 30 amp fuse i believe its fuse number 22 and it looked ok... I also tried unplugging the fuel heater from the outside plugin of the fuel housing...
  #10
Old 01-03-2009, 10:02 PM
Bushwakd's Avatar
Bushwakd
Offline
Member's Gallery
I even did that and still no start. Then went to the fuse panel after no luck scanning the PCM. I thought Fuel Pump because I drained the Fuel Bowl and the pump would not kick on to fill it because of the fuse to the Fuel Bowl Heater.
Human Verification
(View-All Members who have read this thread : 265
/G\EORGE, 01stroke, 02BigD, 1976highboy, 1996timemachine, 19Dually97, 1craneguy, 2000f350v10, 2000XLifted, 35thls1ss19, 7.3Strokin7.3, 700,000 powerstroke, 94powerstroke, 96Crewcab7.3, 96PSD, 97stroker_08, 97WhiteFlatty, ackdog, Adam0331, ajohansson, aklim, altoids, AMB, Arisley, BadDogPSD, baggedbug, bdemutis, bhart, Big Boy Toys, bigbearpowerstroke, bigd4me2, BigRed97, bigtom1, BigTXForddiesel, black4279, BlackHogDown, Blanco Ford, Blowby, boggerr, bonser16, Boomer, BoomerL37, bpa658, brdmh44, brick, bryan rittenhouse, Bugman, Built4tq, Bushwakd, c todd, camd94234, Capricious, carsmars, carwashman71, catfish, charbro, Chilly420@hotmail.com, Chinosandman, chopper, ChuckD, Cjstiles01, Clarence_Carter, clydesdale, Coltaine, connor926, cota, Country, crawlake, CtG, Cupins, d21067, Dave, davidmhowie, dblamp, Detox, Dieselboy, dieselboyf350, dilligaf, DIRTBIKEZ, Dirtyryder, dixieland-diesels, dogmaticus, doubleshot, dstruble, Dustin F2504x4, dzlj 50, dzlstroker, Edwardmcmorris, Ellisd51, Eric Hammond, EXCAV8TER, F-127, F-350, Family XJ, farmboy8201, fatfender, Fever, Ford3544, ford4life76, FTG-05, gcarpenter, genuineford, golfer, goodstktbo, Greg373, have12, hawkeye, HaysKSFirefighter, Highbeam, Hollywood691, HondaTypeRk20, house2311, indyF-350psd, Iowa 73, ironworker25, Ittidneva, jake_v_03, Jcavers, jeepdaddy, jef1988, jeremyroff, Jeron, JerseyJim, jkeller831, jkmcp45, jmac, Jonathanrayce, joness, JSC, ju015dd, Justincredible, kampinguru, kbrickey47, Kcothey, KissCarsDotCom, Ks94.5powerstroke, locrwln, Longdrive, Luke909, madmatt, mandkole, Maroon Harpoon, Martin #6, marx96, Matikus, MATREDGT, Matt07, matthewd11, mattrac, Matt_P, maxndozer, Mbarrett, mbg75, mddevore, Merlin8188, mguttery, Micah99PSD, mikes_stroker2007, mojo25sxt, mooseracer96, motofreak341, Mr. Jimmy, mspainting, MSTR-P, Mudmaker, nasty96, nater77, NeedaTruck, NorCal997.3, ns751, Obspsd7.3, Ohnny101, oldwelder, Owen2002, pat h, Phiber Optik, PitbullOffroad, PolanD RuNz iT, POWERSTROKE03, powerstrokin44, powerstrokin7.3, PowerStrokingMachine, PSD Dually, psd=junk, PSDfan99, ptm22, racerx103, Ramblin'_Man, RandysPSD, ready81, rebel70, redneckdiesel64L, retired jeeper, retired1, reyn7.3, rick cathers, Ripsaw, roachfam2, rob05, Robert_H, rpm-inc, rusty1161, samiam, saw4sun, Schaefer7.3, scheidt27, schwint11, scott3824, scottbeck, screamin6.0, secondarychaos, SeeYa, Sethward, Shovel, shultzinator, silverslug, Slogging, smith7.3, smokydave, smoore5288, SnowFlake, Southpaw, sparksrides350, Specializeddieselnw, squeak12, storker95, stray cat, Stroker67, strokerfan, Super_Hauler, suprdzlduty, tallpowerstroke, tank23, tbolt, tdrracing, TERRCO, The Struggler, thobui, Tim4, Tinscout, Tipher, tommydiesel, Tomygun, tottav, tubes92, turbodiesel_02, txffemt, TxFire, txpsdcrwchf, UNLIMITED_DIESEL, vazuk, white99, White_knight_99, whitjo, Williams2004, william_04_x, wils2527, Wreckedwolf, zach91169, ~9{0BS}6~
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
