I have been chasing a gremlin in my 99 f-550.
Today I had a look at the wire loom from the big connector at the drivers valve cover back to the plug at the valve cover gasket that feeds the gps and injectors on the drivers side.
There is a bare wire in the loom that contains the injector wires. It seems to come from the big connector up to where the wires to the drivers side valve cover branch off, then it just loops back to the connector. I can only see a couple of inches of it and it is a loop, there are no ends.
Can you tell me what it is? Should it even be there?
I did find where a new connector to the driver's side valve cover had been installed. There was some sloppy soldering on the injector wires and the common ground. I am hoping maybe this could be some of my problem with performance. But I am not counting on it.
Thanks
Hud
Merry Christmas.
Thanks
Hud
Merry Christmas.
