Just wanted to know if any of you are running a 6 inch lift with a 2 inch leveling kit to make it 8".
Should i get an adjustable track bar?
And just any info would be great
Thanks
yes u need a adjustable track bar, i drove my truck without one for 3 days because the shop didnt have time to make me one when it was in there the first time,and it was not safe without it, hit a bump and the truck goes where it wants.
I think you are talking about driving with no track bar at all. From what I understand the OP has the track bar correctly dropped for a 6" lift and just wants to add a 2" spacer
with my 8'' bds they used the stock trackbar just used relocation brackets so it worked then i went up to 11-12ish and the stock bar wouldnt work so i didnt have one in the truck for 3 days till i got one custom made...
im sure a adjustable one would work but my local shops said once we order it and if it doesnt work to bad u own it you cant return it so i just paid to have one made
If the axle is centered with what you have now then a adjustable bar will not change anything.
