you can get a gauge anywhere if you want just high pressure you can tap into the port on the top of the hpop under the hood and run your lines in the cab.
has anyone heard or seen of the guy that used a fuel press. gauge for his hpop gauge? looked it up on yahoo, i guess he was just wanting everything to match
no the gauge that was used was a 100 psi fuel pres gauge and somehow hooked it up and just said everything was 40x on all the readings, somewhat of a pain but i guess anything can be done...
Great Dennis, now you have them in stock after I bought Isspro's blue EV2 HPOP gauge :doh: I'm still trying to figure out where to mount mine since the steering column pod won't work on the 05+ trucks
Kainers had the Fuel pressure hooked up to a spare ICP sensor that showed High pressure oil pressure, I believe it was Ford_Forgotten who actually figured it out(not positive though). The factory ICP plug and the Autometer Fuel pressure sensor plug are the same. I am also currently running another ICP sensor with my Autometer GS Fuel pressure gauge, according to the scan tool it tends to be off a couple hundred psi as it goes up into the ICP.
As for an HPOP gauge on the steering column, It sure is alot easier to read there than on the top of the A pillar.
FYI-I have the column mount on my 06 and it fits fine. Not sure why it says it is only good through 04.
